Question about Symbol LS2208 Handheld
When I put the scanner in its holder the beam does not go out, is this right
How do i remove the low beam bulb 2005 chevy cobalt
Under neath the bonnet look for the back of the front lights, there should be a round circle holder which you twist to the right or left and the whole light holder should pop out. Change the bulb and repeat the process you did before except to put back in the light holder and twist to tighten..
Nov 27, 2011 | Cars & Trucks
My scanner sometimes crops a particular slide but not others. Some scan ok. What is going on?
Be sure to put the slide in the holder in the proper direction. The opening in the slide holder is rectangular, not square like the slide. If you place the slide in the holder horizontally and the holder window is vertical, it will crop off the sides of your picture.
Jul 20, 2010 | Plustek OpticFilm 7200 Film Scanner
Left brake light stays on constantly when headlights are on. When headlights are off, left brake light is dimmer than right brake light when brakes are applied. I did recently change the brake bulb. ...
There is a shortage some where at the brake bulb and low beam holder. Take off the bulbs and inspect carefully those losing wires attached to the ends can cause the problem. Good luck.
Jun 25, 2010 | Hyundai Elantra Cars & Trucks
My low beams keep shutting on and off but high beams are fine
this could be solved by taking the bulb out of its holder and cleaning the contact of the bulb and holder.
turn the ignition on after this with the bulbs in the holder and plugged in but not in the headlight kitself.Turn the lights on and see if the work if still the same try moving the bulb while on in its older and see if its just loose. if so holding it one way it will work. wedge something something to hold it in place or buy a used bulb holder.
Check the fuses at the same time and the wire plug that powers the bulb. check and clean the contacts of these also
Let me know how it goes and ill help again if it persists.
bakerboy11@hotmail.com
Automobile
May 17, 2010 | 1994 Dodge Ram
In hp scanjet 2300c light beam is not moving
hi
when currunt scanning and then power off- this prob. apear
open scanner and put light beam to his 1st position (ofkors by hand) than power on and off 2-3 time
(when my scanner's same prob. but my scanner repairering engi. solve it by above method and i see to my eyes this. means this is my showable demo-experience) {sory for bad english}
Dec 16, 2009 | HP ScanJet 2300C Flatbed Scanner
Need to change low beam headlamp bulb
The bulb comes out the back, turn th bulb holder a quarter turn CCW abd pull it right out
The low beam is usualy the same bulb as the high beam, about 6 bucks or so
CAUTION Never touch the new bulb with your fingers, it leaves tiny straks of natural oil that will crack a new bulb
Put your hand in a clean plastic sandwich baggie THEN grab the new bulb ahd it just plugh straight in the holder, replace, turn a quarter turn CW and you're dome
Sometimes they're a ***** to gt your habd behind the bulb, but other than that it's easy
Sep 13, 2009 | 2005 Saturn VUE
I haven't used my Dimage scanner for awhile and I am have a problem with the film holder. I put it into the scanner and no matter how far or how little I push the film holder in, a window comes up saying...
To start ensure that the holder is placed in the right way.
There are plastic tab sensors that are activated by the holder when you push it in, ensure that none of them is stuck.
Try also placing the film upside down and see if that helps.
I am sure that the problem has a simple solution.
Aug 12, 2009 | Konica Minolta Dimage Scan Dual IV Film...
Film holder problem
try this
Turn on the scaner (diode is blinking), then run aplication DS Dual3
After start application you sould hear the transport mechanism test.
The green diode should light permanently (important).
Push deeper the holder.
Jarek
Jan 29, 2008 | Minolta Dimage Scan Dual III Film Scanner
Weak beam
8years old.very weak beam no fault to flash halogen lamp . system seems to be not fully charged
Aug 21, 2007 | MagLite - Mag Charger System 110v (M)...
Symbol LS2208 Handheld Logo
42 people viewed this question
Top Symbol Computers & Internet Experts
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
