Question about Citizen CTS651 Thermal Printer
Length of receipt
My receipt is too long and I can't find how to shorten it?
What is the standard arm length for patterns? I have shorter arms and don't know how much to shorten my pattern
measure your arm from back of shoulder with elbow bent to the wrist bone, of both arms cause some times people are different. then measure the same spot in the pattern down the back of the sleeve you can fold the pattern to represent your arm bent, see what the difference is. if it is not a major amount you can turn it up in hem or cut it off after you get the item done.
if you need to shorten the pattern take a small fold on the lengthen or shorten line to take up the difference in your measure to the arms. depending how fitted it is around the chest/bust area this will factor into the final fit.
Sep 18, 2017 | Sewing Machines
How can I shorten the ringer time on my phone?
I don't know about actually shortening the ring time but if you're not insisting on retaining your ringtone then find one you like on Zedge, download it for free and then use a ringtone maker App to cut it down to whatever length you want. When you're happy just Bluetooth to your phone.
Apr 02, 2015 | Panasonic Lands Phones
How to shorten length of video so you tube will publish it
Use video editing software to cut out portions deemed un necessary till you get the video length down to appropriate time.
Mar 15, 2015 | Computers & Internet
How to shorten power cord on aquabot turbo t
the power cord is factory installed to that length. there is no need to shorten it
Sep 09, 2013 | Aquabot Turbo In Ground Pool Cleaner
Boston Acoustics CS26 Speakers sound cuts out for over a second at higher volumes tested using two different amplifiers same problem. Does not seem to be related to amp distortion:clipping protectio
It sounds like the speaker cones(if that is what they have) get hung up against the back of the case. No vibration=no sound. Check to see that there is no hum adding to the pressure on the speakers. Check to see that the speakers are hooked to the correct impedence output of the amplifier. Also, wire length affects impedence and shortening the wires might help.
Jan 22, 2013 | Boston Acoustics CS26 Speaker
Want to know the proper length of the drain hose from washer to drain. I can shorten it to about 6" if need be
You cannot shorten it to 6 inches. The pipe must go up from the bottom exit up to nearly the height of the washer then down anywhere to drain pipe in wall or washbasin. But the drain hose must go first up and then down - important.
You can give me 4 thumbs, if helped that is.
Jan 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Do I have to lengthen or shorten the length of the float cord on my sump pump if I want it to kick on sooner? Thanks
Shorten. By shortening the cord, the float will trip the switch at a lower maximum depth of water. The pump will run more often as a result, but the maximum water depth will be lower.
Mar 07, 2011 | Flotec 3.4 Hp Floodmate Submersible Sump...
How do I shorten the stitch to make a rolled hem? Please help.
For the rolled hem: the needle is in the O2 or right position, the length is 1.5 in the rolled section- you will see this, if you look on the side of the bottom knob- you can decrease this to 1, but you have to stay within the rolled section, the width is 3.5. the stitch selector is on D, the upper looper selector is UP, the blade is engaged and the subsidiary looper is to the right. You can use a decorative thread in the upper looper- Madeira Decor, Superior Threads made for bobbin work, or YLI Pearl Crown Rayon- or use a wooly nylon for excellent coverage and not need to decrease stitch length. I usually don't need to change the length with these threads.
May 21, 2010 | Baby Lock Evolve
Can i shorten the drain hose of my zanussi 1045 washing machine
it can be shortened without any problem.
Just cut it to the req'd length, but do not make it too short, as it needs to be a certain heght above floor level
Feb 13, 2010 | Zanussi Washing Machines
Receipt too long
According to the printer manual http://www.citizen-systems.com/support/downloads/CD-S500UM5_101.pdf
the length of the receipt is set by your POS software only the width is set in the printer to make sure all the letters fit, or wrap to the next line if needed
There must be some settings in the software that allow headings or other text in what is now a blank space.
Instead of Blanks, there must be an 'off' selection for those items (logo motto operator name etc) and a length for a 'cutoff margin'
cant tell you
don't know the software used
try google for 'configure receipt printing in "software"'
Oct 30, 2008 | Citizen CD-S500 Dot Matrix Impact Printer...
Citizen CTS651 Thermal Printer Logo
16 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
