Question about Kenmore Dishwashers
Who makes the Kenmore 665.17022 dishwasher - Kenmore Dishwashers
My kenmore dishwasher does not start
Perhaps it is defect? perhaps just a circuit breaker tripped?
If it is getting power, does not give any warning and still does not run, ask certified electrician or engineer to look what is wrong.
Jun 19, 2014 | Kenmore Dishwashers
Kenmore dishwasher won't start
check to make sure door is completly closed
Sep 10, 2012 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
Kenmore dishwasher does not dry
The first thing you should do is to turn off yourdishwasher. After that take your Kenmore 16762 Dishwasher manual and make sure ifheating element (calrod heater) is still functioning (it could be broken or burnt). In that case your dishwasher will not keep water hot during washing cycle). If you need manual you can download a copy here!
Jun 03, 2011 | Kenmore 16762 Dishwasher
Kenmore elite dishwasher not filling with water
make sure supply water is goodcheck valve and floater
Feb 07, 2010 | Kenmore 13869 / 13864 / 13862 Dishwasher
Kenmore dishwasher.not working
I decided to buy a new dishwasher! The motor was making a humming noise after the water filled, and there was a burning smell, so I decided to replace the dishwasher!!
Oct 24, 2009 | Kenmore Dishwashers
Dishwasher kenmore
ok this may sound stupid but make sure the power to the dishwasher is on. also I usually find a switch on a wall that shuts the dishwasher on/off is usually off.
Sep 05, 2009 | Kenmore Refrigerators
Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Nov 02, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
