Question about Sony STR-DH540 5.2-Channel Home Theater Receiver
I cannot get components to work through sony str-dh540.
Every once in a while my receiver will not play the components that are hooked up to it (satellite receiver and DVD player). It takes a series of shutting things off and turning them back on again to get picture and sound. My Satellite receiver is acting funny as well and I am on my third satellite receiver in 4 weeks thinking its been the problem but now I think its the home theater receiver. Can anyone help me???
  • 20 Answers
Two things come to mind
- Low input voltage
- Power supply issues
Low Power
As multiple items are having issues the issue sounds that a wiring issues. Have you tried another receptacle (plug) perhaps another room Try plugging only a light to the plug. Does it flicker or appear dim. A multi meter to check line level and a polarity tester to check that wiring is correct. A good power bar will have a polarity tester built in.
Power Supply.
When you must turn on and off a device before it starts working suggests that components have partially failed. Bad capacitors can exhibit this type of issue.
It is possible that a power issue is damaging your hardware. It is always best to use a good power bar. Passive bar are good for a few years. Active should work well for many years. Balance the cost of a power bar to the value of your equipment.
Posted on Jul 19, 2017
snakehead
  • 1074 Answers
SOURCE: Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Posted on Apr 05, 2007
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: STR-DE475 receiver flashes "PROTECT" when turned on
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
Posted on Apr 02, 2009
SOURCE: STR-DE545 Receiver -
Turn the reciever off. Count to 9 slowly. Press the setup button and power on at the same time.let t run its demo. Turn the power off. count to 8 slowly. Turn the reciever back on. Porblem solved?
Posted on Aug 23, 2009
  • 137 Answers
SOURCE: Sound clicks off Sony STR-DE835 5.1 Channel
THIS UNIT HAS BAD SOLDER CONNECTIONS ON REGULATOR TRANSISTORS,REMOVE BOTTOM AND YOU WILL SEE THE BAD CONNECTIONS.ALSO BE SURE TO RE-TIGHTEN ALL CHASSIC GRD SCREWS AS THIS WILL ALSO CAUSE THE SAME PROBLEM.
Posted on Apr 14, 2010
My receiver says the speakers are off
Maybe you can update the speaker driver to see whether it is a driver problem.
Apr 09, 2015 | Sony STR-DH540 5.2-Channel Home Theater...
How do I get solve this problem: the str-dh540 has no output?
Take everything to the nearest Sony-authorized repair depot, for professional trouble-shooting and repair.
May 20, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
How to connect a teac equalizer A220 to a Sony receiver str-DH540
I'm not familiar with your units. The most common set up would be use the "tape monitor loop". Eq out to receiver tape in monitor, Eq in to receiver tape out monitor, then engage receiver "tape monitor" switch on.
Mar 18, 2014 | Audio Players & Recorders
Video in not working
When you plug the AV cables into the receiver make sure that the channel that it is plugged into is selected on the front of the receiver. Also note that the receiver should have a monitor output that should be plugged into the TV and the TV input must be selected on the TV.
Jan 31, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
Apr 14, 2010 | Sony STR-DE835 Receiver
Sony str-dg820. having a problem getting video on tv
Jan 04, 2009 | Sony STR-DG820 Receiver
Sony STR-DG510 From component to HDMI
You have to use the same connection in and out. You can not mix inputs and outputs (Example- HDMI IN will not play on Component out and Vice Versa.)
Nov 18, 2008 | Sony STR-DG510 Receiver
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
Sony STR-DE945-Component Set Up
billr, Go to http://www.retrevo.com/search?q=Sony+STR-DE845&terms=review+manual You should have a pdf of the 845/945 manual waiting!
Mar 11, 2007 | Sony STR-DE945 Receiver
Sony STR-DH540 5.2-Channel Home Theater Receiver Logo
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
