Question about Amana ASD2522WRW - 25 cu. ft. Side-by-Side RefrigeratorWhite
Water Filter I've replaced the water filter and flushed about 5 gallons of water but the water still taste bad (minerally). Any ideas?
  • ray shepard
    ray shepard Feb 14, 2014
    so how do I clear out the lines?
    Master:
  • Amana Master
  • 753 Answers
The minerals could be built up in all the water lines. The water lines in the refrigerator as well as the one that supplys the refrigerator.
Posted on Feb 14, 2014
Testimonial: "How do i clear the water lines then?"
2 Suggested Answers
honeymokey
  • 3113 Answers
SOURCE: bad tasting ice from amana freezer - automatic ice
Do not use a steel or plastic braided line. They make the ice taste bad.
Posted on Dec 14, 2010
Amana ARSE667BS1 refrigerator chilled water taste bad but ice doesn't.New filter and new reservoir.
Run 3 to 5 gallons of water through the new filter to flush it out and prime jt
Sep 02, 2016 | Amana Refrigerators
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
I have an Amana refrigerator, model #ABB1922FEB2. The ice that is made by the automatic ice maker has a foul odor and taste. The water that comes out of our faucet tastes fine, and it's the same water...
Off-taste, odor or gray color in the ice New plumbing connections? New plumbing connections
can cause discolored or off-flavored ice.
Ice stored too long? Discard ice. Wash ice bin. Allow
24hours for ice maker to make new ice.
Odor transfer from food? Use airtight, moisture proof
packaging to store food.
Are there minerals (such as sulfur) in the water? A water
filter may need to be installed to remove the minerals.
Water filter installed on the refrigerator? Gray or dark
discoloration in ice indicates that the water filtration system
needs additional flushing. Flush the water system before
using a new water filter. Replace water filter when indicated.
See "Water Filtration System
To purchase a replacement water filter, model UFK8001AXX-750,
contact your dealer or call 1-877-232-6771 U.S.A. or
1-800-807-6777 Canada
Good luck Please rate FIXYA Thanks
Mar 28, 2011 | Refrigerators
Our Ice and water has a awful taste now. It wasn't used for about 2 months, now it taste awful, do i need to have some one come look at it.
You need to replace your filter, but first run about 5 gallons (the more the merrier) of water through the dispenser. After you do so, then replace the filter and run another gallon of water through the dispenser. The idea is that you will want to clear all of the water through the reservoir inside the fridge compartment and give your water a "fresh start". IF after you try this you still have a foul taste, you can call a servicer and have the reservoir replaced but you should be all set with this method.
Good luck with this!
Aug 19, 2010 | KitchenAid KSRI25FN Side by Side...
Our new Samsung fridge has horrible tasting water
add water filter system to the unit ..
if it is not the water from the unit that bad then filter change might need to be done...or a new filter need to put inside.
Dec 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
The ice and water from my refrigerator taste bad
run the water thr it for about 5 mintes and flush out theline.
Mar 09, 2009 | Refrigerators
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana ASD2522WRW - 25 cu. ft. Side-by-Side RefrigeratorWhite Logo
41 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
