Question about Motorola MC9000-K Portable Terminal
MC9000 password reset
Cannot login as password has been changed and wireless is turned off
    Problem Solver:
  • 13 Answers
Try to disconnect the backup battery
Posted on Mar 10, 2014
Want to change wifi password because I do not want teenage daughter using right now
Hey;
Changing password on a router is quite simple. Depending on which router you have, the factory login and password might differ.
First you have to log into your router. use
http://192.168.1.1
Then you will be prompted for user id and password
login: admin
password: admin
or password
if you are using a verizon router, use
login: verizon
password: password or password1 (when you type the password it will show multiple dots for each character)
if your router has a different password already pre-set then you will have to reset your router. This will change your network name and reset the password to factory setting, like above.
Locate the reset button in the back of the router. While the router is turned on, press the reset button for 10 to 15 seconds and release. The router should now reset. Once it resets, just fallow the steps above. You may also click on the "Wireless" tab and change your network name as well.
Hope this helps.
Feb 03, 2014 | Computers & Internet
How can i change the username and password for this router
If you know the current one, just login to the admin interface, find the 'SECURITY' section and reset it to whatever you want. If you do not know it, you will need to reset the router (usually a simple push-button on the bottom or back - press and hold for a few seconds) and then login using the default login/password for the router and start over.
Aug 26, 2013 | TP-LINK TPLink TLWA5210G 24GHz High Power...
Forget my router password
if you forgot your wireless password or your router password then you can login to your router from your browser by going to 192.168.0.1 the default router login is admin/password or 1234.
go to wireless and then you can change your security password.
if you are unable to login to the router from a browser then you will need to reset your router to factory settings by holding the reset button in with a paper clip for 30 seconds while powered on. then login and reconfigure your settings. you will need to reconfigure all your wireless devices to join your wireless network after this is done.
Feb 23, 2012 | D-Link Computers & Internet
How can i change the password? the problem is i forgot my old pass work.....
Hi
Which password for login password or security key. if you forget the login password then you reset your router and put the password admin, and if you forget security key then lo problem login and open the router go the wireless setting and change WAP or WPA1 what ever you select your pre shared key.
Jun 02, 2011 | D-Link DIR-615 Wireless Router
Where do I find the password for my D-link? Is it the encryption code or is it something else?I have a DIR-635
Hello jean635,
As for the password for your D-Link router, there's 2 passwords you could be referring to.
1) The password to login to the router itself
2) The password for your wireless network
If the password you're looking for is the one to login to your router (192.168.0.1) and the password has NOT been changed, you should be able to login with the username "Admin" and a blank password. If that does not work then you would need to factory reset your router using the "Reset" button on the back of the unit.
If the password you are looking for is the one for your wireless network, then you would need to login to your router, navigate to the wireless network settings and you should see the password there. If it's just a bunch of circles, you would need to change the password to a new one and make the necessary changes to the settings on your computers/devices that connect.
If this helped, please rate, thank you!
May 25, 2011 | D-Link Computers & Internet
Someone installed the wireless router and I now own it and want to change the SSID and make it secure. How do I do this?
you can reset the router to factory defaults by holding in the reset button and powering on the router for 30 seconds.
do this until all the lights on the front flash
login to the router with a laptop/pc connected via cat 5 by opening internet explorer or firefox to 192.168.1.1
the login is blank and the password is admin.
go to wireless and you change the ssid default linksys to another name.
go to wireless security to setup encryption on your wireless to wpa or wpa2 if your devices support it.
setup a wireless passphase to secure your wireless network.
use the passphase to connect to your wireless network.
to change the router default password go to administration and go to management to change teh default login/password for the router.
Mar 27, 2011 | Linksys Wireless-G Broadband Router
Where can I find the password/key for my netgear wireless router
Do you mean the key to log onto your wireless network? Plug a computer directly into the wireless router via the ethernet cable and go to 192.168.0.1. or 192.168.1.1in Internet Explorer. I believe one of those default address for netgear routers. Login to the router, the default login is login:admin password:password then select 'wireless settings' on the left and you should see the key.
If any of the default info has been changed and you cannot login, you will need to reset by pressing the reset button for 30 seconds. But you will have to reconfigure the wireless network and reconnect all computers that were previously connected.
Nov 06, 2010 | Computers & Internet
How can we open the router configuration without password.......& usernane
Dear Friend,
If you don't have change your password from factory defaults then look into manual for user name and password...
If you have change your password then, Sorry you have to reset your router. this will delete all your configuration but will set your login id and password to factory defaults... ( there is no other way)
Please rate the answer
Jun 08, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I have forgotten my password for my routerwhen i go on to www.routerlogin is there any other way of finding my password
Connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
If above things not work then you need to reset it.
For that press RESET button it is in back side of router.
Press it for 10 seconds.
Then try above stuff.
Let me know if you need further assistance.
Thanks for using fixya.
Nov 24, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Forgot router login for netgear router wgt624
Reset the router from back , Hold the reset key for 30 sec , Make sure router is powered on , Turn off the router for 30 secs and then turn it back on , Your router login would be username : admin and password : admin factory default
Regards:
Chandan
Sep 07, 2009 | NetGear WGT624 Wireless Router
Motorola MC9000-K Portable Terminal Logo
82 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
