I had the same problem, this is how you fix it.
remove the two black screws near the power switch and the plastic switch section should come away from the frame. Inside you should find a yellow wire, if you find this is disconnected from the other yellow wire, plug them back together and you should find the solves your problem.
Hi chrissie, have you put the red safety key back in after moving the treadmill??
reebok rem 11300 treadmill ive just got this treadmill from my sister and the up and down button works but its not lighting up or the tread bit its self isn't working what could the problem be and where would I get a manual for it? It did work at my sisters
The up and down button works nothing is lighting up and the tread not moving what could the problem be pls and where would I get a manual
WIRES disconnected at switch power on
