Code d'activation GS-cam de samsat hd90
Thanks
Error Code P068A?? Any one who can give me any advice i would greatly apperciate it.
ECM/PCM power relay de-energized performance too early not exactly sure what it means. I looked it up in the data base hope this helps
Mar 26, 2015 | 2006 Chrysler PT Cruiser
Tip
BMW Motorrad Fault Codes
10167 Output stage to electric fuel pump GS/A 1200 Idling irregular
Battles to start
Fault appears to start intermittently
Bike may start and ride, then will
appear to have fuel starvation
This unit is situated on the
left side of the tank. It is a
little aluminium unit with
fins on. Check the o-ring
of this unit. Unscrew the
unit and check for
moisture in the cavity
below it. Use moisture
repellent spray and
contact cleaner to clean
this device.
If problem
solving does not
work then
replace the unit.
10218 CAN-Bus Timeout: No
communication with KOMBI
(Instrument cluster) control unit
GS/A 1200 Test with diagnostic
system.
Clear fault code.
10219 CAN-Bus Timeout: no
communication with ZFE (Central
vehicle electronics) control unit
GS/A 1200 Instrument cluster does not activate
properly.
Instrument cluster activates partially
and then fades away.
May start on intermittent occasions
system.
If all else fails
replace the ZFE
control unit.
(Very expensive).
10444 Fuse activated for component block
3 (starter relay, Immo (EWS) ring
aerial, ignition coils, injectors)
GS/A 1200 There may be a short on the battery
terminals or elsewhere. Can happen
in conjuction with fault code 10219.
23971 Rear wheel speed sensor: Signal
implausible
GS/A 1200 Possible dirt on sensor. Dirt on wheel
where sensor lost contact.
system.
Clear fault code.
Replace sensor if
fault code reappears.
24052 Electric System under-voltage GS/A 1200 Starter motor battles to turn
Instrument cluster fades and then
reappears.
Check Battery Voltage
Check that the alternator
is charging battery
Check wiring to see that a
short is not draining
battery power.
Replace battery if
it is not charging
or
Service alternator
24971 Pressure In Front Wheel Circuit To
High
GS/A 1200 Check Wheel Pressure! Release air out of front
wheel to the correct
pressure.
Clear Fault Code
Oter fault codes here http://bike-manual.mozello.ru/bmw-motorrad-fault-codes
on Dec 20, 2016 | Motorcycles
98 gs 4oo codes p1346 the car shakeing when in drive and when i slow down
it is a variable valve timing performance code. it could have a bad actuator solenoid, a bad cam actuator, low oil pressure or clogged passages, a wiring to control solenoid problem, or a bad controller. most often it is an actuator solenoid at fault.
Mar 14, 2013 | 1998 Lexus Gs 400
Aerosoft OMSI Bus Simulator activation code
Need to purchase the software to get the activation code. If you have done so already, you need to contact aerosoft. They will ask you some information and then provide you with a working activation code.
May 29, 2012 | Video Game Consoles & Games
Mi moto es una suzuki gs 1000 año 1980 de cuatro pistones y estoy teniendo problemas con los carburadores, es de 4 carburadores ya la e dejado en diferintes talleres y no queda muy bien el problema es...
de gringo--su moto es 30anos y su carbs tambien--necacitan estar limpio--no usar carb limpia-use un fuerte solution de tienda--compro un Clymer manual para techique-eso importante--digame que sucede
Jun 26, 2010 | 1980 Suzuki GS 750 E
Hello! can anyone help me for the authorization code to activate the photoshop cs3 program? thanks a lot! please email me: think-global-2000@gmx.de! i would be really thankful! serial number...
I need an autorization for CS3 Please. please
Serial#1325-1313-1154-2967-7498-8866
Activation# 3021-8600-2093-8928-2529-1814-5727
Thank you
Apr 15, 2010 | Adobe Computers & Internet
COMO ENCUENTRO EL INSTALADOR DE LA CÁMARA
down load split cam and install it from the site mentioned below run the software then connect your pc , open split cam from the progrrame, in split cam icon choose usb cam your cam shall work,
http://www.giveawayoftheday.com/freeware/usb/webcam-driver
thank you ,
domnickr
Aug 15, 2009 | i-rocks IR-3230 Webcam
GS CAMS
unfortunately I can't give you any technical details since my knowlegde of the GS (or any other bike in that matter) is very limited. However there are a copple of ways you can use your internet connexion to find out more: 1. try http://www.gsresources.com (= GS(X) site worthwhile!) 2. try http://www.google.com and search for intake cam suzuki gs 750 (or otherwise)
Nov 10, 2008 | 1979 Suzuki GS 750 E
I need an activation code for a western europe map
i have tt6.75 maps and device code is ak5sc ascr6 can anyone give me the activation code
Feb 27, 2008 | Nokia N95 Cellular Phone
Computers & Internet Logo
560 people viewed this question
David Payne
David Payne
