Question about Refrigerators
Kenmore side by side refrigerator and freezer is not cold
I woke up opened the freezer and some of the vegetables were thawing and ice was getting wet. The compressor did not go on. The lights worked fine in the fridg and the freezer. After emtpying the contents, I decided to clean the fridg. When I swiped the rag across the controls (which are located on the top-most portion of the front perimeter), the compressor kicked on and acheived proper temperature before the day ended. The Kenmore is about 7 years old. Do I have a problem? Did it fix itself?
  • 6 more comments
  • SEFR Oct 27, 2007
    Dear watugot
    The model # is 106.59532990. And Thank you for the quick response! Awesome.
  • SEFR Oct 27, 2007
    Dear watugot
    the model # is 106.59532990.
    thank you for your quick reply. Awesome.
  • SEFR Oct 27, 2007
    Hi Mike
    The fans/compressor was running so I turned that dial to a point where the fans shut down (not too successful the first two times because I went too far and the fans kick off then right back on).  It took exactly 20 minutes to turn back on.  So is it the thermostat? If so, can I fix it myself?
    Dave
  • SEFR Oct 30, 2007
    Hi Mike
    Thanks for checking in. Saturday when I went to the parts store, it was closed - got there 15 min. late and it wasn't open on Sunday. In the meantime, my wife made a reservation for SEARS to come out - that happens today. So, I figure, "what the heck, I'll let them do it." I'll let you know what SEARS diagnoses and their estimate.
    Dave
  • SEFR Oct 30, 2007
    Mike
    Sears did the job and replaced both the therm and the timer as he insisted you can't be sure it isn't stuck so for the extra 30 bucks I went for it. Feeling like a sap. You might feel good that I hit him with all of your expertise on how to check the timer and the thermostat (just to give it to him a little) butI still caved.
    Thaks for yuor help.
    Next time. I am fixing it.
    Dave
  • SEFR Oct 31, 2007
    Thanks, Mike. Take care. Dave
  • mjmarti Nov 05, 2007
    ge MODEL TPX24PRYFWW. Stopped running. My daughter opened and closed door and it strted running again. Stopped again a few weeks later. opened door and light was on. Began pulling unit out from wall and it started running again. Would best bet be thermostat or defrost timer sticking. What is best way to figure out or should I just replace both and be done with it.
  • sdeluca Mar 16, 2009
    I have a side by side refrigerator/freezer and all of a sudden the freezer was starting to thaw everything and the refrigerator also became warm. I was told the pump in the compressor was shot. Is this a possibility?
  • 290 Answers
It most likely did not fix itself and will give trouble again in the future. If you will post the complete model number I will try to tell you what to look for if it happens again and the most likely components to cause the problem. If it has knobs that you turn for the temp control, you probably have a sticking thermostat that started working when you bumped it with the rag, but it could also have been a defrost timer that was sticking, or it could just have been a coincedence that it started working at that time.
Posted on Oct 27, 2007
  • 2 more comments
  • Michael  Lindley
    Michael Lindley Oct 27, 2007
    Thanks for the model.
    You have a fairly simple control sytem. If nothing was running at all when you opened it ( no fan running in the freezer), You have either a sticking thermostat (most likely) or a sticking defrost timer. You can check the timer the easiest.
    Look under the control box in the fridge and you will see a hole toward the right rear side. Inside the hole you will see a small dial that is designed to be turned with a screw driver one way only.
    When the compressor and fans are running, turn the dial around until you hear a loud click and everything turns off. You should hear the timer motor running slightly. The timers are usually set for 20-30 minute defrost cycles so leave it alone for about 40 minutes. It should click itself back on when the timer runs through the cycle. If it doesn't click back on by itself, you need a timer. It is important that you do this when the unit is running because if the thermostat is not calling for cooling, the timer will not get power to go through the cycle and give you a false diagnosis.
    If the timer works properly, you probably need a thermostat. The only true way to check it is with a volt/ohm meter at the time that it is sticking. Which is almost impossible for a repairman to be there at the same time it decides to stick.
    If your problem is that the compressor is off but the fan is running, you may have a compressor relay that is going out.
    As for the quick response, it was just luck. I happened to be fiddling around on the computer while drinking the morning coffe while everybody else is still asleep. Most of the experts on here are repairmen by day and do this in our spare time.
    Post back with what you find out.
    Thanks/Mike
  • Michael  Lindley
    You should be able repair it yourself. It is not hard, just a little aggrevating sometimes.
    I remove the knobs and pop off the faceplate with a knife blade. There are 2 screws that hold the control under the face plate and 2 under the control box that hold it to the top of the fridge. You will have to remove the long cover that runs down the top left corner of the fridge and the cover from the damper. Before you drop the control box, unplug the fridge because there will be exposed wires on the thermostat.
    You can take the covers and control loose and see how it is put together to see if it is something you want to tackle.
    I always advise caution with the new thermostat that you don't kink or break the long metal tube that comes from it. It is pretty durable, but you need to be careful with it.
    You can go to sears.com, click on parts and enter your model number to pull up a parts list and look at a diagram of all the parts.
    Post back if you need further help.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Oct 30, 2007
    Dave
    Just wanted to follow up on your fridge and see if you got it figured out yet.
    Thanks/Mike
  • Michael  Lindley
    HA HA
    Well, you can't blame the guy for covering his butt. There is a small chance it was the timer, but not likely. At least you do have a 90 day warranty if it gives you any trouble. Glad I could be of help. I would appreciate you rating my solution solved if you don't care.
    Thanks/Mike
My freeser is working other side is not cooling the top vent getting air but not underneath
You need to thaw the ice which has clogged the passageway from the freezer to the refrigerator. To do this, you can turn off the whole unit for several hours and let everything thaw, or you can remove the panels and locate the vent(s). Melt the ice with a hair dryer, then reassemble the panels and restart the refrigerator. There is a small chance that the fan in the freezer has frozen up as well. When the refrigerator compressor runs, you should also hear a small fan in the freezer run. If not, you will need to do some investigating to find out why.
Apr 25, 2012 | KitchenAid Refrigerators
Ice not thawing on the coil?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | Kenmore Side by Side Refrigerator
The refrigerator side is not very cold (mid 40's-50) but the freezer is fine. Not much cold air entering through vent in the upper left side of the fridge.
check the fan and the damper behind that vent if iced up thaw out damper --if fan blocked or iced up clear if fan not running test fan repair or replace if not running -refrig side is cooled by air from freezer side
May 31, 2010 | Kenmore 57029 Side by Side Refrigerator
The freezer is cold but the refrigerator section is not getting cold...it is not warm but not cold according to the dial settings
check the operation of the damper door between the freezer/refrigerator section which lets cold from freezer into refrige compartment for ice build-up which will cause damper door to not open fully and cool the refrige compartment,if this is the problem,unplug the door ans remove and let thaw then replace and try it then
Jan 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water dispenser on refrigerator not working but ice maker is making ice
Most likely a frozen line... If you can hear a faint pump noise near filter when you try to dispense wate, that tells you the pump is woking. rIt could be a frozen reservoir(located on fridge side behind vegetable bins) or the line that runs thru freezer door to the dispenser. Use a hair dryer to thaw out reservoir or try to turn off the unit for a few hours. (That did it for me). If it's the line in freezer door, shut off unit, open freeezer door for a few hours and seal off freezer with a towel or cardboard to keep all frozen. If not this, may be a clogged water line from filter or a bad valve.
Dec 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator or freezer will not get cold
it sounds like maybe a freon problem,you might want to have a qualified technician check it out or get another opinion.
Dec 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Refrigerators Logo
775 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
