Question about Behringer U-control Umx490 USB/midi Keyboard Controller
Behringer U control UMX490 connect to pc
How to connect to pc
Where do you connect a midi controller on a Behringer Xenyx 1204usb mixer?
You can connect where it is possible. I hope you will understand.
Aug 04, 2016 | Behringer Music
I Am Trying To Hook My Behringer X2222USB To My DAW How?
Once connected to the computer you have to open your Daw and find the menu to activate the mixer via midi. Check the user manual of your Daw. Also you might have to do some midi mapping to set up the controls.
Apr 09, 2016 | Behringer Music
What driver of umx49 for os Windows 10
sorry to inform you but windows 10 drivers have not been developed by most other manufacturers . and may never be . recover your old OS in/thru the control panel .
Dec 06, 2015 | Behringer U-control Umx490 USB/midi...
How to use the behringer 802 mixer and connect it to the computer
There are a variety of ways to accomplish this, but the two most common ways are:
  1. Purchase a BEHRINGER USB interface -- like a U-CONTROL UCA222. This will allow you to use the USB port for your sound In/Out. This will also require RCA cables to connect from mixer to UCA222 unit.
  2. Or...purchase a dedicated sound card (preferred) like an M-Audio Audiophile 2496 that can be installed in your computer (not for laptop). You will also need I/O RCA cables to connect.
Dec 26, 2014 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
What's your problem?I have a behringer UMX490 plugged by UBS into my pc . Do I need a specific sound device plugged into the MIDI output or will it play though my computer
Your UMX490 is already provided with an audio interface working via USB
Just hook it up to your computer and you will be able to play the built in sounds.
The MIDI output is for allowing you to control external samplers, synths and other equipments.
Regards
Sep 29, 2011 | Music
Hi I have a Behringer Fcb1010 and I want to programme one of the expression pedals as a volume pedal but am unsure how to do this?
I have Behringer Fcb 10 10,but i want to know how expression pedal volume work when connect with GR55.
Feb 11, 2011 | Behringer Fcb1010 Midi Foot...
I have a Tascam US1641 USB interface and wanted to know if you can connect a Behringer 2442fx to it to use it as a mixdown control for my music in Cubase studio5.
The 2442FX has a built in usb interface so there is really no need to use the Tascam. Here is a link for you:http://www.behringer.nl/EN/Products/2442FX.aspx
Oct 19, 2010 | Behringer XENYX 2442FX Mixer
How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer U-control Umx490 USB/midi Keyboard Controller Logo
23 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
