Question about Samsung 40 UN40D6000 LCD TV
Samsung UN40D6000 While Lines
Started which a ghost image and now i just get white lines all the time. Here's a pic http://tinypic.com/r/25jgzza/8
4 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
milkburp
  • 416 Answers
SOURCE: takes 5 to 8 times to turn on, then has lines in picture
You have bad capacitors on the power supply. This is a common problem. I published a tutorial to guide the DIY persons through the repair. Have a look in my Tips & Tricks if you wish to had a go at the repair yourself. I hope this was helpful, best wishes.
Posted on Apr 25, 2010
SOURCE: I have a Samsung Plasma 4252 and i have red horizontal lines.
I have the same problem on my set. I had a repair technician out today and they wanted to replace the circuit board that the buffers are connected to and the adjacent board that drives the buffers. If you remove the back panel the buffers that are in line with the distorted areas on the screen are running super hot. Estimated price with labor was $700.
Posted on Aug 03, 2010
My Samsung UN46C6300SFXZA started displaying horizontal lines immediately after we moved it to our bedroom when we purchased a new one.
i think you have problem with a display 90% or flat cable between main board t-con and t-con too display is 10% possible
Mar 04, 2017 | Samsung Televison & Video
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Ghosting Samsung UN40D6000
Most likely a LCD Panel failure!
Feb 13, 2014 | Samsung 40 UN40D6000 LCD TV
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
What if my samsung tv has ghosting images/horizontal
thats a convergence issue I will need the model number of your samsung in order to assist further with the issue.
Mar 19, 2013 | Televison & Video
I need some parts for Gerry Crib model no. 9021. Where can I get those?
HERE IS A INSTRUCTIONS AND PARTS HOPE IT HELPS
These assembly instructions are for Evenflo crib model 9021 manufactured in 1999. When you click on the link, click on the image, select "view raw image" and you will be able to use magnifier to zoom in.
(front and back) http://tinypic.com/view.php?pic=2ufeg7o&s=5
(pg 1&2) http://tinypic.com/view.php?pic=315cyeq&s=5
(pg 3&4) http://tinypic.com/view.php?pic=33578ma&s=5
(pg 5&6) http://tinypic.com/view.php?pic=2cy3709&s=5
May 18, 2009 | Evenflo Jenny Lind Crib
I need screws for the Gerry 9021
SEE IF THIS HELPS GOOD LUCK: These assembly instructions are for Evenflo crib model 9021 manufactured in 1999. When you click on the link, click on the image, select "view raw image" and you will be able to use magnifier to zoom in.
Feb 13, 2009 | Evenflo Jenny Lind Crib
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
We need assembley instructions, or schematics
HOPE THIS HELP YOU OUT GOOD LUCK These assembly instructions are for Evenflo crib model 9021 manufactured in 1999. When you click on the link, click on the image, select "view raw image" and you will be able to use magnifier to zoom in.
Jan 01, 2008 | Bassett Mission Crib
Samsung 40 UN40D6000 LCD TV Logo
362 people viewed this question
Jerry Greenberg
Jerry Greenberg
