Question about Lind Computers & Internet
I have a Linden Quartz Chime mantel clock. It stopped running and I'd like to replace the entire battery pack, but can't find the parts. Do you have any idea if they're available? It's not an expensive clock, but I'd rather fix it than throw it away & replace if possible.
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register ยท My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
Dunhaven mantel clock
You may need to try and repair the quartz movement, this link will help you out.
http://usedclockparts.com/14-clocks/clock-videos/126-quartz-battery-operated-clock-movement-repair
Jan 19, 2014 | Home
Linden mantel clock
Make sure all the batteries have been replaced, that the batteries fit tight, check for loose wite connections. If that is all good, you will need to replace the chime box or the whole movement.
Jan 10, 2014 | Home
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
How to reset wesrminister wall chime clock
If this is a mechanical clock, make sure the chime lever is set on. If quartz there is a reset button to forward the chime advance until it matches the hands.
Mar 19, 2013 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Apr 05, 2010 | Seiko Mantel Clock
Seiko Westminster Chime Clock; Model No. QF0020 (or QF002G)
There is a small potentiometer that the volume know is on, probably replacing the pot will fix the problem. Radio Shack has these.
Nov 10, 2008 | Seiko Mantel Clock
Computers & Internet Logo
137 people viewed this question
Top Lind Computers & Internet Experts
David Payne
David Payne
Are you a Lind Computer and Internet Expert? Answer questions, earn points and help others
