Question about Canon Office Equipment & Supplies
Cannon MP 270 stuck with the error message
I was using it as a copier and it got an error but when that was sorted it wouldn't stop flashing the number of copies left and E. I have used the red reset button to no avail. Left it un plugged for well over a week but it still wont clear and can't be used till it does. I can't find a real reset button on it but can you help please?
  • non_hannon
    non_hannon Feb 14, 2014
    Thanks, will try that now
  • Canon Master
  • 365 Answers
Non
Will the ink cartridges move to the center?
If so take them out and unplug the machine for 30 minutes.
Plug it back in.
Hopefully this will reset it to thinking it is a new machine.
Posted on Feb 13, 2014
4 Suggested Answers
munnabhai
SOURCE: Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Posted on Sep 21, 2008
HobbesVT
  • 3 Answers
SOURCE: Drum life low replace soon Error Message
I already answered this at some other place here - but just to make sure the word gets out there:
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner assembly - and you can rotate it counterclockwise all the way back. This should reset the drum counter - worked for me!
I hope it also does the trick for you ;-)
Posted on May 04, 2009
santosj27
  • 263 Answers
SOURCE: SC550 Error. Ricoh MP
That error code refers to the FUSING WEB END.
First of all you must see if the fusing web is end.
If the error occurs before the web ended you have to upgrade your firmware. There is a release firmware that corrects this symptom.
Posted on Feb 23, 2011
How can i get instalation software for PIXMA MP 270
Go onto the canon web site and download the driver from there, its easy to do and you will get the latest driver
Jun 13, 2014 | Cannon Office Equipment & Supplies
Tip
Error P22 CANON PRINTERS MP 240-250-260-270-280
If appears error P22 at this printer CANON MP 240-250-260-270-280 means you need to replace first the scanner,if the problem persist you need to replace the logic board.
on Apr 06, 2011 | Office Equipment & Supplies
How do i rest my cannon pixma mp 220
I would imagine the error message is asking you to hold down the reset button of your printer for 5 seconds due to a low ink estimate with these refilled cartridges. If this is the case the STOP/RESET/RESUME button is represented by an upside-down triangle in a circle and is normally red or grey.
More information on this error message can be found here.
Hope this helps.
Sep 12, 2012 | Office Equipment & Supplies
Normnpam@bigpond.comCanon Printer MP 270 Need Instruction manual.
you can find complete support including the instruction manual on the cannon website at this link:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp270
Aug 16, 2011 | Canon imageCLASS MF7480 Laser Printer
I have a cannon MP 510. When I turn it on, the carriage slams right and left. Then the lights on the front flash Green (left) Orange (right), Green (left) and Orange (right), then stops flashing for a...
I suspect you had a paper jam and removed it from under the main cover. It sounds like you have got grease on the encoder strip (the long blackish plastic strip that runs the full width of the machine. The carriage looks at the encoder so it knows where it is. Clean the encoder with soapy water on a cotton bud. You may have even snapped the encoder which will mean you will need a new one.
Good luck
May 26, 2011 | Canon Office Equipment & Supplies
MP 270 Code 5 155 55
Hello
You may consult to nearest cannon service for this error
good luck
Mar 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My cannon mp 270 printer error 5200. i m olready change ink
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 28, 2010 | Canon Office Equipment & Supplies
Why is my Canon Pixma MP 270 flashing a number 6 and a letter E ??
It is a Cartridge error.To fix press the "stop\reset" button for 5-7 sec. and then release it.
Let me know,if that does not solve the problem.
Good Luck!!
Thanks!!
Aug 21, 2010 | Canon Office Equipment & Supplies
E5 flashing - do not want to use colour ink
use any color cartridge that is no sort & see canon error e5 solution
Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
108 people viewed this question
old marine
old marine
