Question about Samsung Touch of Color UN46B6000 46 in. HDTV LCD TV
Un46b6000vf clicks i have change power supply and main control bd's
  • Samsung Master
  • 4,018 Answers
If you have changed them and still clicking it is the inverter board at fault. could of saved your self some money if you invested in a multi meter, and inverter problem will shut down the tv. as the psu has a built in shut down for faults.
Posted on Feb 25, 2014
Testimonial: "yOU NEED TO ASK IF I HAVE A METER FIRST BEFORE SAYING I NEED ONE. ALL SO IF I UNPLUG THE MAIN PLUG TO THE CONTROL PCB THE BACK LIGHT COMES ON WHICH OFF COUSE IS THE INVERTER BD DRIVEN"
  • 2 more comments
  • Dennis McCollum Feb 25, 2014
    ALL SO THE INVERTERS ARE ON THE POWER SUPPLY BD IF YOU KNOW ANYTHING ABOUT THIS MODEL.
  •  Russ Hill
    Russ Hill Feb 25, 2014
    Samsung LED Backlight Strips inverter lighting board in the rear of the screen. when one fails it will shut down tv board..
    Thanks. Is there a way of juming these so it wont shut down.I heard you can jump the inverters on the row thats bad,is this true
  •  Russ Hill
    Russ Hill Feb 26, 2014
    you need to find witch one that is failing. it can be as low as just 0.05ohms reading the led row can still be working but the power to is changed and the psu know the change in the volts. they are easy to fix when you get the one out at fault its usually the one in front of the screen driver board as this one or two can get over heated from the this board heating the back of the screen.
I have a LG 55LV5500 TV. It started out intermittent it would power off. And now will not power on.
It could be either the main or power board, if you are comfortable doing it pull the back off and look for a pin on one of the connectors that says PSON...stands for power switch on and measure the voltage at that pin, if you have nothing the power supply board is bad, if you see a few volts on that pin push the power button on the TV and see if the voltage changes, say if its at 3 volts does it go to 5 volts or if its as 5 volts does it drop to a couple volts, if you see that happen then the main board is working and you need a power board, if there is no change its the main that is bad...Good luck!
Nov 27, 2017 | LG Televison & Video
Has backlights,has power dc voltages to power supply bd.,but not tcon bd.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Oct 12, 2016 | Televison & Video
Samsung hp-t5054 plasma - no picture or sound - beeps at power up- has power - funny electrical smell when pluged in.
You will need to have a good tech check the set out.
There is no way to know what part/s have failed. Parts that fail are the Y-Main bd, Power Supply, X-Main bd, Y-Upper Scan bd and Buffer bds. Last is the Panel has shorted,causing a cascading component failure. Very expensive if that happens.
Apr 06, 2010 | Samsung Televison & Video
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
SAMSUNG LNS3251DC - RED POWER LIGHT IS ON BUT TV NOT POWERING UP. WHEN I PRESS THE POWER BUTTON NOTHING HAPPENS. TV HAS A DARK GLOW COMING THOUGH
Multiple causes here. The Main bd controls the Power supply. The Main bd receives the "Power on " signal from the IR sensor and the Power Button the tv. Seems that the Main bd is not sending the Power on signal to the Power supply. So the first place to start is with the Main bd. Second being the Power supply. have a trained Samsung tech troubleshoot the set.
Jul 11, 2009 | Televison & Video
Poping sounds on start up then went dead
There can be any one of the following failed parts. The FET'S on the Y-main bd have exploded and may have taken out the Main Power supply as well. The Y-Main Upper Y-Scan bd may have some blown up IC Flat pacs which will cause a chain reaction taking out the Y-Main bd and the Main power Supply. The X-Main bd could also have failed. It is best to have a trained Samsung tech troubleshoot the set to find the bad parts and repair the set.
Jul 09, 2009 | Samsung SPN4235 42 in. Plasma HDTV
My Dell w4200hd will not turn on. The color on the little light by the power on/off switch will change from what I think is standby color to a different color when I try and turn it on, and I hear...
i do have the power supply at my shop. but i don't think the power supply is the problem. i already replaced the power supply on this set with this symtom and no help. you can find parts at discountmerchants.com J.D.W.
Mar 08, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Hooked up laptop to tv vga in. TV shut down
Not a good problem, Polaroid units have a control box that contains the main bd, power supply and av bd. When the unit fails you must replace the entire control box as you cannot buy individual parts for this unit. Try the Vance Baldwin or Andrews electronic site for part information.
Feb 23, 2008 | Polaroid FLM-323B Television
Samsung Touch of Color UN46B6000 46 in. HDTV LCD TV Logo
240 people viewed this question
Jerry Greenberg
Jerry Greenberg
