Question about John Deere 310sj Backhoe
Return to neutral seat switch needs bypassed on john deere 310SJ
Need to bypass return to neutral seat switch so the alarm will quit beeping
How do i wire the seat switch for l120
Don't understand what you mean..the switch is a single wire going to and from the switch with plug connectors on the end..setting on the seat makes contact by pushing the switch allowing operation getting off disconnects it..If you are talking bypassing it temporarily to test it..I do not suggest a permanent fix...just use a jumper wire between the wire ends..it will bypass it...Remember it is a safety switch...and should never be permanently bypassed...hope this is what you were looking for...good luck..
Aug 30, 2015 | John Deere Garden
How can i bypass an operator presence switch on a john deere gs 30
This is a seat switch. Look for wires that go to the bottom cushion.
May 28, 2015 | John Deere Garden
450 john deere neutral switch problem
The switch needs replacing. Try bypassing it first. Find the wires that go to it and strip off a small bit in the insulation and short them together. Note: It might be a switch that 'disconnects' the connection, so then just cut one wire.
Dec 21, 2014 | Garden
Bypass RIO/PTO on john deer 1025R jractor
RIO/ PTO switches can not be bypassed. These switches are part of the safety circuits. Trying to bypass switches might cause other electrical problems, which that is NOT what you want.
Oct 15, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Bypass neutral switch
nope... you need to figure this out yourself...
Sep 08, 2014 | Garden
John Deere 790 stalling out
My problem with my John Deere 790 stalling was my safety seat switch. It's a quick fix! What I had to do to fix my 2006 John Deere 790, was:
1. Un-hook the switch wires under the seat that connect to the seat switch.
2. Then, connect all of them with little wire clamps (or you can use a raw wire and connect them all) inside the wire connector, with the 4 connectors in it, to bypass the seat switch. Hot wire all of them together. It somehow resets the switch.
3. Then, with my 790 Deere in neutral, I started it up and held the key in starter position for about 2 seconds. (Instead of letting go right when it fires up) Somehow, in doing this, the seat switch reset and I was able to reconnect the switch and the seat switch works as it should now. My Deere 790 front loader fires right up without stalling now, while in neutral, of course. So, try this first because it's a quick fix. I hope this helps.
Cheers,
Aaron
Nov 15, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere LX 178 wont start
check the seat switch also as these can be touchy too,just temporarily bypass it
Jul 17, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 310sj Backhoe Logo
197 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
