Blu Ray no sound
I bought a wireless (wifi connected) blu ray player but when I hook it up I can only see the picture. There is no sound. I do not have an HDMI TV which the instructions say is the best way to enjoy blu ray. However, it does give video and coaxial install instructions as well. The back of the blu ray only has the yellow video output, the coaxial black and the HDMI hookup. No audio outputs on it. My television, again not HDMI equipped, has the standard red white yellow on the back. I have the chord with the 3 colors on each end. I tried an adapter piece in the coaxial output and then plugged the red and white audio in it but no luck. Suggestions on what to do to get it to work?
4 Suggested Answers
  • 6 Answers
SOURCE: My HDMI cable wont work from my new Blu-Ray player
On the blu- ray player you have to set it to HDMI in the options or else it wont work
Posted on Oct 24, 2009
  • 909 Answers
SOURCE: Hooked up blu ray player with HDMI cable to Sony
goto this link and click on the "connect blueray disc player" icon, this will guide you through.
Posted on May 18, 2010
SOURCE: can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Posted on Jun 29, 2012
Dusername login
Does your blu-ray player have wifi and have you input the wifi details into the blu-ray player? Have you used the correct security protocol for the wifi password? Is the blu-ray player further from the router than the pc? Unfortunately there are a lot of potential issues here...
Hopefully it will be something like the wireless security protocol you're using in which case you're just checking to see whether both devices are using WEP or hopefully WPA/WPA2.
Nov 23, 2013 | Computers & Internet
I cant connect to the internet
what error message you get when you try to connect to wifi network ?
Nov 19, 2013 | Dynex Dx-wbrdvd1 Blu-ray Wifi Player - Blu...
Hi, I just bought a blu ray home theatre system and hooked it up, the surround sound sounds great but it only works when my watching a movie with the blu ray player... I hooked the blu ray player to my tv...
If you want everything to have surroud sound, it all has to run through your system and you select which function to use. Yes it sounds like improper connections.
Sep 03, 2011 | RCA Audio Players & Recorders
I have bought a new Blu-Ray player, a BDP-S570, which I am trying to connect to my LG TV. The TV is a 50PX4D and has one HDMI port that I have previously used to connect a Sky HD box to with excellent...
There are no compatibility issues. In your BluRays HDMI audio settings set the audio out to PCM instead of bit stream.The TV cannot decode digital bit stream audio.
May 16, 2011 | Sony BDP-S350 Blu-Ray Player
I loast connection to my wireless router. How do I reset the connnection.
Check your router to make sure it's broadcasting a wireless signal. If it's not, then reset it by unplugging it for 5 seconds before plugging it back in. There should be a light that comes on that indicates wifi is enabled. If that doesn't work then check your router's wireless settings. If it's not the router, then check the wireless settings on your blu-ray player
May 04, 2011 | Panasonic DMP-BDT100 Blu-ray 3D Player
A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Apr 11, 2011 | Vizio VBR231 Blu-Ray Player
I have a sharp aquos blue ray BDHp24u, that says it is capable to get internet for netflix. What do I need to get a connection. I have a verizon wireless router. Do I need to hook up anything to the...
You would connect an ethernet cable between the bluray player and wireless router. If the wireless router is too far away you would need a Sharp PLC adaptor
Jan 09, 2011 | Sharp AQUOS Blu-ray Disc Player
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Televison & Video Logo
Top Televison & Video Experts
