Question about Samsung BN94-04355B Main Board for UN55D7000LFXZA BN41-01622A, BN97-05202A
How to clean led screen
Clean finger prints
Ve 2512 printer can adjust machine to print 4x6photo. Print picture on 81/2 /11 only
What photo editing software program are you using? Photo dimensions are usually set in software. You can set what size paper you want in the printer setup section of the printer driver.
Aug 12, 2016 | HP LJ472UTABA Notebook - Elitebook 8460p...
How do i get finger print and colour pen marks off my JVC LED tv
Don't use house hold cleaning fluids. There are great sets with microfibre cloth and fluid, special developed for flatscreen tv and monitors. You can buy hem in almost every electronics store.
Jan 20, 2015 | JVC TV 55" LED 120Hz 1080P 3D JLE55SP4000
The screen has a smudge on it. It is on the picture also.
If this is a new camera, then the sensor has a finger print on it... if it has just started, then then lens has a finger print on it and the lens needs to be cleaned..
if the problem is internal, then return the camera for a new one..
heatman101
Sep 27, 2011 | Canon PowerShot SD1300 IS / Digital IXUS...
Cleaning the fingers prints, etc off the screen.
Don't use anything with alcohol a lite damp cloth is all very soft one at that. do not rub hard you may damage the surface.
Apr 30, 2010 | Toshiba 42H81 42" Rear Projection...
How to clean finger prints off screen
You can buy LCD screen wipes they should do the job.
Feb 03, 2010 | Vizio Televison & Video
Magenta LED head appears broken
What you need to do is power off the machine. Open the top cover and look at the Magenta LED print head. At the right end there is a white flat ribbon cable plugged into it. Pull out the cable and let it dangle BEHIND the print head. Close the cover and power up. You will hear no motors and eventually you will get a fatal error 13x. Power OFF and push the cable back into the head after wiping the back of it with your fingers. Be careful and make sure it goes in straight. If happy and it looks like the other three then power up again. You should hear the motors once again and all should be well. If you still hear nothing then turn off immediately and follow the instructions again. If you get it wrong then you may have shorted out the control board which renders the machine useless. You do this at your own peril. It usually cures all its problems. good luck
Mar 30, 2017 | OKI C5150n Led Printer
THERE IS SOME FINGER PR INTS IN OUR LCD MONITOR WANNA ASK HOW YO CLEAN AND REMOVE TNE FINGER PRINT
The best way is to buy a special microfibre cleaning cloth for LCD monitors. Very often the same cloths are used to clean sunglasses so you may already have one of those. Do not use any cleaning liquid. Rub the screen very GENTLY with the cloth until the prints are gone. You can rub fast but remember not to press too hard or you can damage your monitor.
Oct 11, 2009 | Likom HD15A 15" LCD Monitor
How do I clean the screen to clear finger prints.
You need a proper cleaning solution for the new flat panel screen. The best I have tried is Monster ScreenClean. This cleaner comes with a microfiber cloth and actually repels dust and fingerprint buildup. I use it on my big screen and it rarely needs cleaning now.I have used it for three years and works great. Hope this helps.
B.Crowell
Apr 22, 2009 | Sanyo Televison & Video
Samsung BN94-04355B Main Board for UN55D7000LFXZA BN41-01622A, BN97-05202A Logo
12 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
