Question about Lowrance iFINDER H2O C GPS Receiver
Will not turn on
It will not tun on
Assembly instructions Hampton space saver
what you are showing there is the locking screw removed from the panel and locked where it should be
use a philips screw drive and turn the screw a half tun and that will allow the screw to be pulled from the panel shown
screw that screw into the corresponding panel and then put the panels together over the dowels and the screw that you removed and fitted just fitted will go back in where you took it from
hold together and turn the philips screw a half tun and it locks the panels together
all this is explained in the assembly instructions
Oct 24, 2016 | Dryers
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
CANT CONNECT http://192.168.0.1 TO CONFIGURE ROUTHER
Hi. Try this: turn your computer, router and modem off first (make sure the router and modem are unplugged from the power source). wait for 2 minutes then turn the modem on, wait for one minute then tun the router on, wait for another minute then tun the computer on. Go to the command prompt and key in ipconfig. see if it gives you a default gateway. if it does, then key in ping192.168.0.1. it should give you 4 replies. If it does, then you should be able to access the GUI, if it doesn't then there could ba a problem with the connection between the computer and the router. Check if they're properly connected to each other. :-)
Jun 04, 2011 | Computers & Internet
How do i conect my tv aeriel to my projector and get it tuned in on the projector ?
Since most projectors don't have built in tunning ( they only have audio/video input jacks), you'll have to use another source for tunning - one that has a/v output with built in tunning. The best source would be a vcr or dvd recorder with a built in tuner.
reply to this post if you require further assistance.
Dec 28, 2009 | Televison & Video
Tuns off when I turn on the psp
maybe the battery. buy a new one most new ones run for 25.00 bucks at gamestop. ebay you can find some but the cheap and you can trust its brand new!
Aug 19, 2009 | Sony PlayStation Portable (PSP) Console
Ps3 tuns on but no homepage and controllers not responding right
Check out #3 on my 5 common problems with the PS3.
Just google my username.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
When i tun it on it says lens error!??
Seems your camera gone mad and needs Electronic Doctor immediately. :D
Jul 31, 2008 | Canon PowerShot SD600 Digital Camera
Time set and LAP
With the radio turned off and displaying the time, hold the MODE switch until the time display flashes (about 2 seconds). Release the MODE switch then quickly, use the TUN (up) to set hours, TUN (down) to set minutes.
Oct 06, 2007 | Koss PP257 AM/FM Radio
How to set Stations
u set up the channel u want with "tun.up"\"tun.dn" press the "mem.ch" for five sec untill it flickers or beeps now u know its in the memory do so 4 any station u want
Feb 01, 2006 | Jensen SAB-55 Radio
Lowrance iFINDER  H2O C GPS Receiver Logo
11 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
