Question about Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked and will only turn on the hand held not the top shower
    Top Expert:
  • Grohe Master
  • 34,763 Answers
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Posted on Feb 13, 2014
3 Suggested Answers
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 1044 Answers
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Posted on Dec 20, 2009
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
Grohtherm 3000. The shower looses pressure after about 30 seconds. If I turn off the shower and then turn it on again the same thing happens again. There is no problem if I use the wall mounted heads.
I'm not familiar with that specific shower but I assume you are refering to a hand-held shower head. Probably calcium build-up inside the head. Immerse it in Limeaway for an hour or two.
Oct 26, 2010 | Grohe Home
Low water pressure in grohe hand held. Is there a
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
I have a Grohe shower head that leaks buckets (not an exaggeration). We bought the parts that we were advised to buy from Grohe, but even the professional plumber couldn't stop the leak or install the new...
sounds like you need volume controls lots of grohe fittings are strictly mixing valves not shut offs if this valve use to work then you need to find plumber familiar with grohe
Feb 21, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Grohe hand held shower head stopped working
This is a simple fix. The tools you need are: cresent wrench. You want to remove the shower hear off of the pipe coming from the wall. On the inside of the end off the shower head there should be a small plastic disk remove it. It will have a series of holes this is called a water saver. The holes get stopped up with minreals take a tooth pick and clean them out. I see this all the time. If that does not work it will be in the valve
Feb 03, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
The Grohe Movario shower head how do unscrew it to clean the head
On the face of the shower head where the water sprays out of ,their should be a threaded nut to unscrew This is called the aerator.This is the part wher the filter screen is .Once you clean this part you should be up and running.
Jan 25, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel Logo
172 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
