Question about Samsung 40 UN40D6000 LCD TV
Samsung UN40D6000 white lines - Samsung 40 UN40D6000 LCD TV
I have a double image on my Model Samsung UN40D6000 tv S/NSNZ2ZFCEB502294V.
Good morning
Try Menu and find picture there, adjust contrast, brightness,and sharpness. I would start there.
kolbrub
Sep 28, 2015 | Samsung Televison & Video
Tv won't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 22, 2014 | Samsung 40 UN40D6000 LCD TV
Double picture
Double picture equals bad LCD panel, time for a new TV.
Feb 14, 2014 | Samsung 40 UN40D6000 LCD TV
Ghosting Samsung UN40D6000
Most likely a LCD Panel failure!
Feb 13, 2014 | Samsung 40 UN40D6000 LCD TV
Where are the external controls such as volume and power on or off on this tv
According to Samsung touch controls for power, volume, channel, menu and input should be locate on front panel. Usually it is located on the bottom right side and look around outer edge of panel with a flashlight ( they hide them well).
Oct 15, 2013 | Samsung 40 UN40D6000 LCD TV
Need onwers manual for 42 in led slim tv mod lg42le5510\tb
http://www.amazon.com/Samsung-UN40D6000-40-Inch-1080p-Black/dp/B004NB4TTA
Jan 24, 2012 | Televison & Video
Remote control code for UN40D6000
Only one Ive found for the 6000series is 1340
Nov 26, 2011 | Samsung 40 UN40D6000 LCD TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung 40 UN40D6000 LCD TV Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
