Question about Microsoft Office Professional 2007 Full Version for PC
When I start word 2007 it takes me into the Safe Mode?
  • Microsoft Master
  • 1,087 Answers
That sounds as if there is an error in Word software. Try starting in Safe Mode then loading Word.
Let us know what happens please.
Posted on Feb 13, 2014
My 2007 BF Falcon wagon occasionally misfires when starting causing it to go into 'safe mode' with dash instruments flashing. The car can be driven with reduced power, sufficient to get home.
Your car should be fitted with an obd2 connector. Go to your local dealer and ask him to download the error codes on the ecu it will give the reasons causing the vehicle to go into safe mode.
Dec 16, 2013 | Ford Fairmont Cars & Trucks
How do i start my pc in safe mode
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
May 02, 2012 | Dell Computers & Internet
Hp slimline s3000 goes immediately into sleep mode
Try booting into Safe Mode then go into the Control Panel and change the Power Options.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Once safe mode is up click Start/Control Panel and look for Power Options.
Apr 08, 2012 | Computers & Internet
@i bought in 2007 the e macines windows vista home premium, and i get an error code that claims i have a registry error, how can i fix this
You didn't give us much information, but I would start the computer in safe mode, if possible (hit F8 when the computer is starting up--keep tapping on it until you get the screen that lets you choose safe mode.)
Once the computer is running, do a system restore back a few days or so to when it was running OK.
Other suggestion, rather than safe mode on startup--choose "repair my computer."
Jun 02, 2011 | E-Machines eMachines Desktop PC
Safe mode in mac G5 2007
Press and hold the shift key on start up and release it when you hear the apple sound. That will take you into safe mode.
Sep 30, 2010 | Computers & Internet
Can't run outlook 2007
Try opening Outlook from run command window
Start > Run > Outlook /safe
If it works fine close outlook
Go to following registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins
HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins
Delete the addin key from the regitry
Happy computing :)
Apr 09, 2009 | Microsoft Office Outlook 2007: Windows
Crc failed in Enterprise.ww\enterww.cab
Based on my experience there are many reasons that this issue may occur. I
suggest you try the following suggestions:
* Suggestion 1: Clear Temp folders
1. Click Start>Programs>Accessories>Disk Cleanup
2. Clear your Temporary Internet files and temp files.
3. Restart the PC.
4. Copy your Office 2007 files and folders to a local folder.
5. Double click on the Setup.exe to start the install process.
* Suggestion 2: Check the Environment Variables
I remember I have resolved some similar issues that the users report Office
2007 has failed to install. I have figured out this is caused by the wrong
configuration of the user variables. To check it, please follow the steps
below:
1. Right click on Computer, and choose Properties
2. In the Tasks list that appears on the left, click Advanced system
settings.
3. Click Advanced tab, click Environment Variables.
4. Under User variables for user name, check if TEMP is configured as the
following value: "%USERPROFILE%\AppData\Local\Temp"
* Suggestion 3: Install under Vista safe mode
Please try to install Office 2007 under Vista safe mode:
1. Restart Windows.
2. At the boot sequence, long press F8 key to invoke startup menu.
3. Choose Safe Mode with network connection on the menu and press Enter.
4. After Windows starts in this mode, install Office 2007 again and see the
result.
Feb 04, 2009 | Microsoft Office Professional 2007 Full...
MS Word 2007 will only open in SAFE mode
I had the same problem. Ran the updater, reinstalled, and still had the problem. Searching for and deleting Normal.dot fixed it immediately. YAAAAAAAAY!
Jan 30, 2009 | Microsoft Office Professional 2007 Full...
"Hold" Button on console beside gear shift - what's it's purpose - we don't know!
Owner's Manual says "You can select this mode to drive with some characteristics of a manual transmission. With the HOLD mode turned on, the automatic transmission will stay in a specific gear range.
Press the HOLD button on the shift lever to turn on the HOLD mode.
While on, the HOLD indicator light on the instrument panel will light up..."
The button is on the console, next to the shift lever, and the HOLD indicator light is in the lower left hand corner of the instrument panel
Oct 12, 2008 | 2007 Suzuki Forenza Sedan
Virus prob
first if possible update the virus definitions, second, go into safe mode by pressing F8 right before your computer starts to boot up, choose safe mode. third, do a full scan of your whole system. this should eliminate the virus. make sure though you do it in safe mode. hope this helps you.
Sep 20, 2007 | Symantec Norton AntiVirus 2004 - (Open...
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
