Question about GE Cafe CGS980S Kitchen Range
Replace oven sensor
Oven does not maintain temperature, then after I shut it off, then turn it back on, it heats too much. I imagine the oven sensor has gone bad--how do I replace it?
SOURCE: GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
SOURCE: F2 error
I have the same problem... I unplug the range wait 30 seconds ...the plug it back in..usually works. Remodeling soon .. next range not GE!
Posted on Oct 06, 2007
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
  • 262 Answers
SOURCE: no heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Posted on Dec 22, 2007
SOURCE: oven
Same here, my wife freaked cause Christmas turkey took 6hrs.
I read somewhere that its internal thermostat. GE should offer to look into this seemingly wide spread problem
Posted on Jan 01, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Nov 22, 2009 | Hotpoint RGB745 Gas Kitchen Range
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
My oven keeps beeping F2 and it won't turn off. The top broiler coils are bright red and heat is pouring out of the oven. I have held down the off button, pushed start, pushed bake, anything I can think...
Control senses oven temperature above 615F-630F. shut down the breaker switch asap.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jul 08, 2009 | GE JGRP17 Gas Single Oven
Fan in oven will not shut off, F-4
Hi jsachse,
The F4 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Dec 18, 2008 | Magic Chef 31000 Gas Kitchen Range
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven turns off and displayes F2,F3,and sometimes F4.
5550 The error code ?F2? will be displayed along with a beeping sound if the ERC (Electronic Range Control) or ?clock? senses a runaway heat condition during the ?cook? or the ?clean? modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC. If the error code ?F2? is displayed in the ?cook? or ?clean? modes only, then the problem is a bad oven temperature sensor or its wire harness. If the error code ?F2? is displayed in the time of the day mode also, then most likely a problem is the bad ERC. The access to the oven temperature sensor plug and the wires is from the back only. You have to pull the oven out of the wall (if it?s free standing) or remove it from the cabinet (if it?s built in). Disconnect the power and remove the rear cover. Check the resistance across the oven temperature sensor. It is supposed to be about 1100 Ohms at room temperature. If the resistance is incorrect, the oven temperature sensor is bad and needs to be replaced. If not, check all the wires from the oven temperature sensor to the ERC. Replace all wire nuts if any. If it is not the sensor and wires, you have to replace the ERC. To get the right replacement part just click on the link http://tinyurl.com/34ujtl , then type the model number of your oven in the search box, click on the ?search? button and in the new window type the word ?sensor? or the word ?clock? in the ?search by keyword? box and click the ?search? button. Gendos post back...
Jul 07, 2007 | Maytag MER5550 Electric Kitchen Range
GE Cafe CGS980S Kitchen Range Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
