Question about Maytag Refrigerators
Class solutions freezer works but fridge doesn't
    Master:
  • Maytag Master
  • 753 Answers
Need much more info than that, I will be glad to help but need more info. Maytag authorized.
Posted on Feb 14, 2014
  • 1462 Answers
SOURCE: I have a Beko -
i assume this is a frost-free type.
remove the back panel inside the freezer and check if the pipework is frozen up. if so, melt the ice off with a hairdryer and get back to me for further details
Posted on Sep 04, 2008
toolkits
  • 1099 Answers
SOURCE: freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
Posted on Jul 28, 2010
heatman101
  • 43501 Answers
SOURCE: We have moved our Whirlpool
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Posted on Jun 12, 2011
richroth
  • 9472 Answers
SOURCE: Freezer works, fridge doesn't ~ need a solution!
What is the model number of the unit?
Posted on Nov 14, 2012
Sea Breeze
  • 4655 Answers
SOURCE: my fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
Posted on Dec 01, 2012
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Kenmore Top Freezer Refrigerator
Have an upright Brandt fridge/freezer A-Class. The freezer is on the bottom with the fridge above. At the top of the fridge there is a AMS (air moving system). The freezer works fine but the fridge is not...
the freezer has ice build up which is blocking cold air from being blown into the fridge,defrost entire unit overnight and retry if good but fault returns then you have a defrost problem
Jan 31, 2018 | Refrigerators
We have moved our Whirlpool A Class Fridge Freezer and it doesn't seem to be working now, can you help?
heatman101
Jun 10, 2011 | Whirlpool Refrigerators
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
I have a Beko - CDA659FS Class FN TYPE1 Fridge Freezer and although the light works in the Fridge Freezer the fridge is no longer working, Can you help ?
Sep 04, 2008 | Refrigerators
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
