Question about Video Game Consoles & Games
I had installed popt2t but it was not launching..!
I am unable to launch any microsoft office programs. Whenever I double click on any program, it doesn't launch at all. Before, I was able to launch all the MS Office programs. When I right click to go to...
Try to launch your programs directly from the installation directory, by default: C:\Program Files\Microsoft Office
If you are able to launch them, it is only the shortcuts that are somehow modified.
If it's not the case, I recommend you to repair it with the installation disk.
Mar 05, 2010 | Microsoft Office Professional 2007 Full...
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
I have the Aspire 5630 and I'm using windows 7 but I want the setup file of the launch manager because the multimedia buttons don't work. Thnx.
Alright, so I have the Aspire 5630 and after installing Windows 7 32 bit, the media keys did not work. Just installing the latest Launch Manager didn't work. But here's what did work for me: Install the 3.0.04 version of the Launch Manager (LaunchManager_Dritek_3.0.04_W7x64W7x86_A.zip) If the link doesn't work, just select the Acer Aspire 7730 in the Service & Support section of their website, choose Windows 7 as the OS, and you'll see the Launch Manager under the Application tab.
After installing that and rebooting, the media still didn't work for me (though another user reports that they worked at this point). What I then did was download the latest Launch Manager for the Aspire 5630 for Vista (same deal as before if the link doesn't work, but select the 5630 and Vista instead). Extract the .zip, then take the "LManager.exe" file from the zip and replace the one in "C:program filesLaunch Manager" (back up the existing one if you so desire.) If Launch Manager is already running, right click on it's icon in tray and close it, then launch the one you just copied over (which will also now be the one that is launched automatically on start).
At this point, all of my media keys were working.
Hope this helps!
Dec 22, 2009 | Acer Aspire 5630 Notebook
New p c game will not launch
If you installed from CD - Have you tried it with the CD in? Many games do not install completely to the hard drive and require the CD to run. If you downloaded it from another source, try installing it again.
Dec 13, 2008 | Intel Motherboard
My CineDash Media Console will not work anymore. The volume, stop, play, etc. does not work. Not with itunes anymore.
This is the way to get it to work!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager here (hosted here) or go to the acer site and find it there. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Nov 06, 2008 | Computers & Internet
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
Video Game Consoles & Games Logo
63 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
