Kyowa induction cooker
The code is EO & no heat
3 Suggested Answers
SOURCE: eo error on display does not heat a stanless steel
call me : 9994191598
Posted on Apr 12, 2010
  • 4 Answers
SOURCE: I have pigeon induction cooker.
what about steel/iron utensils?
Posted on Feb 15, 2011
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
Eo error code
CHECK DISH, CHECK CAPACITORS IN CIRCUIT,CHECK COIL
Jun 19, 2013 | Winco Professional Induction Cooker -...
SUNFLAME INDUCTION COOKER IS SHOWING E9 ERROR CODE AFTER HEATING
Ihave a sunflame induction cooker. Whenever i start after 2 min it shoes e9 and stop working what is the reason
Jan 26, 2013 | Cooktops
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
What does EO means on LED of a induction cooker
i have longer induction , problem is EO error on the display..
i changed(IGBT,Fuse,Capasiter) what i do?
Jul 03, 2009 | Cooktops
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
