When I photocopy or scan a document with my samsung CLX-6220FX a pink/purple vertical line appears down the left hand side. I have tried cleaning but nothing seems to be getting rid of it. But it does not happen when we print. I have tried changing cartridges and still no luck.
flopez
  • 161 Answers
SOURCE: Samsung CLX-3160FN All in One Printer
You have a small trace dust or error correction fluid (like Liquid Paper) allocated in the thin, rectangular piece of glass that seats to the left side of the scanning glass. Clean this small glass carefully and the problem should go away.
Be blessed.
Posted on Sep 29, 2008
Corysf62
  • 188 Answers
SOURCE: C524 has narrow vertical slashes down left hand side
This problem is 99% of the time the photoconductor. Try removing and reseating. If this does not work, try another one. Even though you state that you just replaced it, on rare occasions, defective ones get shipped out. Usually the manufacture will replace the defective unit for you when this happens. Also make sure that the locking tab that holds the developer in place did not crack and therefore loose. I have seen this many times where the clip that holds the developer is damaged.
Posted on Oct 06, 2008
beboybutiki
  • 126 Answers
SOURCE: I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Posted on Sep 23, 2009
SOURCE: Epsom RX420 all in one
Silly daft me, never usually change the setting on the scanner, and didn`t know that having left a folder on top of the scanner the other day it must have nudged the setting and altered it.
Settings are quite tiny and it was dark and the room not very well lit where the printer is, so it was trial and elimination and only after pratically looking through a magnifying glass sorted it.
Alls ok now, thanks for asking.
Sandra
Posted on Jan 21, 2010
dj_relly999
  • 4070 Answers
SOURCE: When I photocopy a document, a thick black line
Hi! As a first course of action I strongly suggest that you run cleaning on the printer properties. This may get rid of the black line. HOpe this helps and thank you for using FixYa!
Posted on Sep 24, 2010
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
How to get rid of vertical lines in scanned documents in bizhub 200?
Open the top cover of the machine and clean the small glass on the left hand side. Good luck.
Dec 27, 2012 | Konica Minolta bizhub 200 Printer
Horizontal lines on photocopies made but no lines appear when document document is printed.
Hi there, As it sounds its a dirty scanning glass. Open the top of the scanner so that you can see the scanning glass.. If your standing in front of it you will see on the left hand side a strip of thinner glass.. Take a damp cloth (better cloth with spirits/surgical alcohol) and clean the both the small and the large scanning glass. These lines normally cause if the glass is dirty. Especially if your using the document Feeder. As a lot of time wet ink or typex or correction fluid gets stuck on glass which will cause these lines.
Hope it helps
Regards,
Jul 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I got a Samsung CLX 3175 when I scan or copy or vertical lines comes out on the paper. But when I print from the computer it works good.
Hi!
If you lift up the document feeder where you set your documents you will see a thin piece of glass to the left,clean it with a damp cloth and it will be gone!!
Enjoy!!
Jan 14, 2011 | Office Equipment & Supplies
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
open the scanning unit. in scanning unit clean the mirrors.
Sep 16, 2008 | Samsung CLX 3160fn All-In-One Printer
On an HP 3050, a vertical line appears on the left side of the scanned document when using the software proviced with the machine. How can this line be eliminated?
Try cleaning the glass strip to the left of the larger piece of glass. A tiny spec of dirt will cause a long vertical line when scanned through the feeder.
Aug 19, 2008 | Office Equipment & Supplies
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
13 people viewed this question
jasbo
jasbo
