Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Connectivity how to connect 5.1 speaker system to computer sound card In speaker 3 nos out put and in computer only one input is there
  • Anonymous Sep 05, 2008
    Microsoft windows xp. only two "remote" speakers operating. Everything checked in Microsoft set up but no change..
    inspire 5.1 5300
    Novelist:
    Champion:
  • 382 Answers
Possibly using a subwoofer as the bridge? Logictech makes a 3 to 5 converter.
Keep me posted.
Posted on Oct 28, 2007
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
I bought a logitect with 5 small speakers but i have 3 imput but my computer has only one. how do i connect
Unless *********** board was bought years and years and years, and even years ago, you should by default have at least three jacks. Headphones, or sound out; micorphone, and a line input or second out put. You can adjust your settings in the control panel under audio devices to have a least two (2) outputs, in which case you want to connect the green and black. You should have instructions that came with the system to show you guidelines for setting up the speakers, but you can then use your matrix feature to mimmick surround sound!
Jun 05, 2011 | Logitech X-540 Computer Speakers
Sound cuts out and what is replaced is a pulselike sound
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 10, 2011 | Bose Companion 5 Multimedia Speaker System...
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
I have just bought the logitech x-540 speakers and have found that they have 3 input cables (one for each of the left, right and centre speakers). However my laptop only has 2 input 'holes'. The...
Hi bud , What your laptop has is a 2.1 Channel Sound card , and your speakers are a 5.1 Channel Surround Sound system ...So in order to get the Real pure surround sound , Sound out of the speakers you will need to buy a 5.1 Channel Sound card...
Hope you come right bud
happy new year :)
Jan 06, 2010 | Logitech X-540 Computer Speakers
Need cable to connect computer to BA7800 speaker system
YES, WHERE CAN I GET THE 3 PRONGED CABLE TO CONNECT MY SOUND CARD TO THE INPUTSON THE BACK OF MY BA7800 SPEAKER SYSTEM, OR JUST MAKE MY OWN WITH 3 GOLD TIPPED 1/8" CONNECTOR WIRES?
Jun 14, 2009 | Boston Acoustics (BA7800) Computer...
My speakers will not play on my computer
Mar 08, 2009 | Boston Acoustics BA735 Computer Speakers
Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Oct 16, 2008 | Koss HD 50 Computer Speakers
Logitech X-540 connecting to dell dimension 3000 ???
Your problem is you have a 3 channel sound card on your dell and you bought 5 channel speaker system. You can plug the green to green and get 2.1 sound but you will have to by a 5.1 pci sound like in the link below to get the full use of your 5.1 system.
http://www.mikescomputershop.com/asus-xonar-d2pm-sound-card-p-2357.html
Sep 08, 2008 | Logitech X-540 Computer Speakers
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
61 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
