Question about Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code
Zm400 bblock I get bbblock v 37 error at start up. Ive got it since the first time. any help?
LA IMPRESORA ZEBRA ZM400 CUANDO SE ENCIENDE APARECE EN LA PANTALLA LCD, EL MENSAJE HEAT OPEN, COMO QUITARLO?
there is a possibility that you need to just the print head assembly, if when its at close position, the print head is far from the sensor.
With the print head is open, you will see 3 screw on the left, louse them and adjust all the print head mechanism, up and down some milliliters tie the screws again, close the printhead , try again and see if errors desapeer
Jul 24, 2014 | Zebra ZM400 Thermal Label Printer -...
Zm400 feed
Please uninstall the printer driver and reinstall it again
Nov 04, 2013 | Office Equipment & Supplies
How to solve this problem in zebra zm400 error condition paper out \
check the sensor under the paper, reload labels roll, labels are possible on top of sensor black plastic and not between. move gap sensor to midle of label with. check manual to know how to fit the labels thought the sensors and printhead.
Sep 17, 2013 | Zebra ZM400 Thermal Label Printer -...
CHANGE PRINT HEAD
Wow Dude, Im telling you Ive made chances of Thermal print heads for Kodad, Mitsubishi, and Agfa Printers... And Im warning you, theres no easy way to do so. It is Not user serviceable... Youve a Minimum of 40 screws to pull out. Lots of plastic pieces... and a lot more of "extra-pieces-that-I-dont-know-where-they-came-from" once you finish and close it up. The main Idea is for you to call the official service to do so. But, if yourre handy im telling you. Start unscrewing disassemble everything very carefully, and youll end up taking it out easily. GL
Jul 05, 2012 | Zebra ZM400 Thermal Label Printer -...
Error condition
Already try reset the printer to factory defult? ( turn off, press pause and cancel button at the same time and turn on, wait 5 secounds and relese the buttons.
Feb 01, 2011 | Zebra ZM400 Thermal Label Printer -...
Says paper is out says ribbon is out. Both are loaded properly. Says head is open. It's not. Turned off and on. Received error code bblock v23
I am having the same issue. Please help. Not having luck with this printer. I thought it was easier to print some labels.
Jun 23, 2010 | Zebra Thermal S4m Dt Zpl 203dpi Rs232/par...
Error in position of the output for ZM400
this is usually caused by a pressure imbalance across the printhead. Check the printhead pressure adjust dials located on top of the printhead. You might find that the left side has more down pressure than the right side causing the ribbon to move to the right.
Hope that helps !
Apr 09, 2010 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Aug 10, 2009 | Zebra 105SL Thermal Label Printer
There is error "bblock" on zebra s4m printer printer is not detecting with pc
BBlock is BOOT Block. The printer is not booting up the settings completely. Probably got corrupted. You will need to download the bootblock version for this printer & upload it via either USB or LPT1 port. You should contact Zebra so they can direct you to the proper Zebra site for the download & instructions. The process of the upload is no more that 15-20 minutes.
Zebra phone # is 847-913-2259 I think option 2 is tech support. be sure to have s# of printer & tell them you need to find the boot block & installation info for the S4M. Good luck.
Feb 07, 2009 | Zebra Z4Mplus Label Printer
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code  Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
