Question about Water Heaters
I need to reset my Halstead iheat35C boiler but do not have the instruction manual. Could you help please??
    Problem Solver:
  • 5 Answers
Posted on Apr 06, 2014
4 Suggested Answers
  • 171 Answers
SOURCE: instructions for my Ideal Mexico CF60P Propane boiler
Hi tessajoe,
I'm Harvey, the master plumber. You asked where you can
download instructions/user manual/installation guide for
Ideal Mexico CF60P Water Heaters. I believe this is the correct link:
http://www.chspares.com/partselect.php?test=121
Some Companies will e-mail it, others will respond if you call them on the phone and they will fax it or mail it. Contact info on the link that you requested form me.
I'm happy to help you!
Feel free to contact me.
Harvey the Master Plumber
Posted on Sep 09, 2008
  • 44 Answers
SOURCE: how to check if pressure switch on halstead boiler 82 combi
Hi I am thinking what your tryig to say is the air pressure switch?
you can check this switch to see if the boiler works by removing one of the sensing tubes from it & by sucking on or blowing as this willactivate the switch you dont have to do it very hard, just gently as you will hear the switch clicking, if the boiler does fire when you click, in order for it to continue to ignite you may have to fold over the tube, when you release it the boiler should stop.if it does work then you will have to change the air pressure switch, but remember this can only be done by a Corgi Engineer
Kindly
Richie
Posted on Dec 20, 2008
  • 150 Answers
SOURCE: halstead ace high boiler making a whining noise
Whining = pump bearings
Pressure reduction = pressure relief valve diaphragm either perished of gunged up - look for water coming out of the overflow pipe from the valve
leak in ch system look at all joints
Posted on Dec 01, 2009
Halstead free standing boiler ignition working but no hot water or heat?
Does the gas valve click/clunk? In the fan operating. Need to know more
Mar 03, 2014 | Water Heaters
My pressure is low on my halstead eden cbx24 boiler, i can find the loop to fill it up but dont know where to put the water in, can anyone help?
Do you have a sight glass that shows water level in boiler on this loop? If so is it marked where normal water level is supposed to be? There should be a water line connected to boiler with a valve on it. This will be a manually operated valve unless it has auto fill control. Locate this valve and slowly add water until level in sight glass is back where it should be,then shut valve.While you are doing this the boiler should be at operating temperature because hot water expands and you don't want to overfill. There should be a temperature and pressure relief valve on top of your boiler to prevent unsafe conditions but I wouldn't count on it working properly if it is very old. My main concern is for your safety so if you are unsure of something don't do it. If your boiler has a automatic water make-up on it then you need to have a service tech. find out if it's not working,and repair or replace it. I hope this helps you. Thanks
Nov 24, 2010 | Water Heaters
I HAVE A HALSTEAD ACER HIGH BOILER AND IT IT IS SAYING LOCK OUT ON THE BOILER WHAT CAN I DO TO FIX IT
The overload button is on the left underside of the unit. There is a finger sized hol and the button is in there. Once you have reseet the button you will also have to reset the boiler by using the switch on the control panel (furhtest left switch).
Dec 03, 2009 | Water Heaters
Halstead ace high boiler making a whining noise when central heating is turned on also pressure reduces after about 4 hours, need to top up verey day.
Nov 30, 2009 | Water Heaters
I have a Halstead High Ace which will not light up the light flickers then goes off we have fitted a new dectection electrode but still will not light the boiler We also have flushed the system out ....
sounds basic, but make sure the electrode is in the pilot flame
check the overheat thermostat is not jammed on
disconnect and join wires together for temporary override check and run boiler.
Nov 14, 2009 | Water Heaters
Halstead boiler reluctant to stay on
next time it turns off let it cool and clean with a cotton swab with rubbing alcohol after brushing.
Aug 31, 2009 | Water Heaters
Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Mar 31, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Water Heaters Logo
136 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
