Question about HEWLETT-PACKARD Probook 4530S
HP 4530s laptop won't power up. Amber light where adapter plugs in.
There might have been liquid spilled on the laptop. Not sure. Looks Ok.
2 Suggested Answers
  • 6771 Answers
SOURCE: I spilled liquid on my HP Probook 4320S (with spill resistant keyboard). Dried it up straight afterwards. Now it won't power up
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
Posted on May 06, 2012
My PC laptop hp 4530s does not turn on after water fall on its keypad and i have drained it but it still does not work,what can i do?
You have to make sure that the motherboard is dry before turn it on. Actually, when the liquid spilled on your keyboard, you have to detach the main battery first. If you have plenty of time, then you can disassemble the laptop, make it dry (especially the motherboard), and reassemble it.
Feb 16, 2014 | Computers & Internet
HP 4530s will not power up no matter if the power source is plugged in or with battery. When I push the power button there is nothing happening. I noticed that just above where the power plug in to the...
Try another cord/charger with the EXACT same power specs. Has the cord been pulled while it was plugged into the laptop damaging the AC jack? If you have a multimeter you can verify you are getting the correct DC volts at the laptop ac jack plug. Try HP Support for a explanation of the small led blinking: http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?locale=en_us&taskId=135&prodSeriesId=5060880&prodTypeId=321957
Apr 07, 2013 | HP Computers & Internet
Wifi wont come on
Unplug, remove battery, plug in, reboot, any change? Have you done ALL the Windows and HP updates? Open the Device Manager, open Network Adapters, is the Wireless adapter enabled, in error? You can find the driver for the Wireless adapter here, choose your OS: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=4145202&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=4145198
Mar 05, 2013 | HEWLETT-PACKARD ProBook 4520s
When I plug in my HP 530 Green light comes on then turns to amber. Will not come on even when I remove battery and just plug in. 1322dijim@gmail.com
The System / Motherboard has faulty Power Circuit. Contact HP and arrange a repair. If under warranty won't cost anything.
Jul 05, 2012 | HP 530 Notebook
Probook4530s not recharging. powercord or recharging device problem
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 15, 2012 | HEWLETT-PACKARD Probook 4530S
May 06, 2012 | HEWLETT-PACKARD ProBook 4320s C Notebook
Blinking white amber light above power cord
The power supply is the issue, or the DC jack in the laptop has developed bad connections, or ram issue. Remove 1 stick of ram and power on, if no! remove second one, and replace the first, power up, if no! test the power supply for proper voltage, if okay! it is a DC jack or motherboard problem.
Mar 09, 2012 | HEWLETT-PACKARD Probook 4530S
My hp laptop won't power up. I bought a new power cord and connected to my laptop and the power light won't come on, so what esle can i do to get power to my laptop?
Have you followed the Guided Troubleshooting steps provided on the HP Support web site?
These will take you through a series of checks and decisions to try to isolate the cause of the problem along the following lines:
1. Are you sure you are plugged in to a good power outlet - can you plug a lamp in and does it work?
2. Are you sure that you are using the right power adapter for this laptop, is it the original HP block supplied with the laptop or is it a replacement - if the latter, then does it supply the correct output voltage and watts required by the laptop.
3. Are you sure the problem is not just the laptop display being dead, i.e. have you tried attaching an external display, do you get any leds light on the laptop for power, disk activity etc?
4. Have you tried removing the battery from the laptop and connecting the power adapter with it removed to prove that the battery is not preventing the laptop from powering on?
5. Have you disconnected all external devices from the laptop, in particular docking station, printers, USB devices etc to ensure that no external device is preventing it from powering on?
6. Do you have another power adapter that you can try using - are there any lights on the power adapter to show that it is working?
Jan 05, 2012 | HP Compaq 6820s Notebook
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Liquids spilled on keyboard, was unplugging u nit when I saw the screen starting to corrupt, at that point I pulled out the b/u battery as well as unplugging. Dried out unit before attempting to restart....
Impossible to able fix that because since you spilled the liquid and when liquid gets on chips and fried right way, try to sent to computer store and let them look at it
Feb 11, 2011 | Computers & Internet
HEWLETT-PACKARD Probook 4530S Logo
32 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
