Question about Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline
Boiler reset I need to reset my Halstead iheat 35C boiler but do not have the instruction manual. Could you help please?
    Sergeant:
  • 287 Answers
What does this have to do with vehicle care and maintenance? regardless, find the manufactuers website and im sure you can track down the pdf file that answers your question for that model
Posted on Apr 27, 2014
My pressure is low on my halstead eden cbx24 boiler, i can find the loop to fill it up but dont know where to put the water in, can anyone help?
Do you have a sight glass that shows water level in boiler on this loop? If so is it marked where normal water level is supposed to be? There should be a water line connected to boiler with a valve on it. This will be a manually operated valve unless it has auto fill control. Locate this valve and slowly add water until level in sight glass is back where it should be,then shut valve.While you are doing this the boiler should be at operating temperature because hot water expands and you don't want to overfill. There should be a temperature and pressure relief valve on top of your boiler to prevent unsafe conditions but I wouldn't count on it working properly if it is very old. My main concern is for your safety so if you are unsure of something don't do it. If your boiler has a automatic water make-up on it then you need to have a service tech. find out if it's not working,and repair or replace it. I hope this helps you. Thanks
Nov 24, 2010 | Water Heaters
I'm trying to get hold of a Halstead CBX boiler 'user guide' and a Halstead RFTH1 room stat 'user guide'. Where can i get these docs?
Here is a site that seems to have everything in that line...
May cost you a few $$ but it will be worth it...
Halstead Boilers Ltd
heatman101
Oct 02, 2010 | Heating & Cooling
I HAVE A HALSTEAD ACER HIGH BOILER AND IT IT IS SAYING LOCK OUT ON THE BOILER WHAT CAN I DO TO FIX IT
The overload button is on the left underside of the unit. There is a finger sized hol and the button is in there. Once you have reseet the button you will also have to reset the boiler by using the switch on the control panel (furhtest left switch).
Dec 03, 2009 | Water Heaters
Manual required for Maxol Homewarm 600 or Maxol Morocco 20 Boiler
If he can't fix your boiler without having the instruction manual then he can't be much of an engineer. i would ring someone else.
Nov 19, 2009 | Thermos Kitchen Appliances - Others
Halstead boiler reluctant to stay on
next time it turns off let it cool and clean with a cotton swab with rubbing alcohol after brushing.
Aug 31, 2009 | Water Heaters
Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Mar 31, 2009 | Water Heaters
I have a 6 year old Halstead Ace High boiler which has many recurring problems due to a bad fitting. It was never flushed out causing the heat exchange needing to replaced TWICE through clogging and then...
Firstly your system needs a power flush to get rid of the grot, then it needs a good inhibitor to slow up the reappearance of the sludge.
Changing the boiler won't help. Any boiler will get clogged up but the halstead DHW heat exchanger is particualrly prone to getting gummed up. You can clean this out and refit without having to buy a new one. - but without a power flush it will happen again.
Jul 31, 2008 | Heating & Cooling
Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline Logo
83 people viewed this question
Top Medline Vehicle Parts & Accessories Experts
baire
Lawrence Oravetz
 Russ Hill
Russ Hill
Are you a Medline Vehicle Part and Accessory Expert? Answer questions, earn points and help others
