Question about Danco Faucet Cartridge
Brizzo r66600 rp42216 cartridge handle in 6 oclock pos turns towards 9 oclock to get water need to change so can turn from 6 oclock to 3 oclock pos can i rotate or adjust stem arrow on body faces away
Water on/off is in the wrong position after changing the moen cartridge in my shower
Put your cartridge back the way it was originally. By rotating 180 you reverse the hot and cold. Leave the handle and plastic adapter off. Turn on your water supply and turn valve with the plastic adapter until the water is shut off. Remove the adapter and install it with the set screw for handle facing down. Put your handle back on and that should take care of problem. (I did the exact same thing as you today....small world)
Feb 16, 2013 | Moen Posi-Temp Single HandleTub And Shower...
Adjust anti-scald delta B114900
Adjusting the anti scald is pretty simple on this device. Attached is a photo of breakdown for this. Basically, unscrew the labeled part to access a very small black rubber gasket. Remove the black gasket to gain access to the anti scald part. You have have to use needle nose pliers to remove the black gasket but it does come off. Once you have this part off, you will see the two parts (with teeth like a wheel) that will adjust the hot water levels. Remove the part on top and turn the little "handle" clockwise towards "3'oclock" to make the water hotter. The part itself will not allow you to go past "3 oclock" for safety reasons. adjust-anti-scald-delta-b114900-ucghvzot5faznyh4jdqs4e5n-4-0.jpg
Jan 19, 2013 | Delta & Single Handle Shower Faucet
2001 dodge ram 1500 5.2 v8 van spark plug diagram
firing order is 1 8 4 3 6 5 7 2 standing in front of truck. cylinders on passenger side facing you are 2 4 6 8 cylinders on driver side facing you are 1 3 5 7 now this is your spark plugs wires location on distributor cap.with distributor facing you.2 plugs wire on cap 6 oclock position 1 plug wire on cap 8 oclock position,8 plug wire on cap 9 oclock position,4plug wire cap 10 oclock position,3 plug wire on cap 12 oclock position,6 plug wire on cap 1 oclock position, 5 plug wire on cap 3 oclock position, and 7 plug wire on cap 5 oclock position. in order for this to work you must be standing facing the engine all plug wire location on cap should be correct.
Apr 08, 2011 | Dodge Ram 1500 Cars & Trucks
I need a wiring diagram for the ignition control module and distributor on a 2.8 litre v6 motor
OKAY STANDING IN FRONT OF ENGINE ON LEFT SIDE CYLINDERS FACING YOU IS 1 3 5 ON RIGHT SIDE DRIVER SIDE CYLINDERS FACING YOU IS 2 4 6 LOOKING AT DISTRIBUTOR CAP NUMBER 1 SPARK PLUG ON CAP IN THE 9 OCLOCK POSITION YOUR NUMBER 5 SPARK PLUG ON DISTRIBUTOR CAP IN 6 OCLOCK POSITION .STARTING AT NUMBER 1 SPARK PLUG ON CAP COUNTING CLOCKWISE COUNTING 1 2 3 4 5 6 THATS YOUR SPARK PLUGS WIRES ON CAP TO ENGINE PLUGS. 6 PLUG WIRE ON CAP IS AT 7 OCLOCK POSITION.
Feb 07, 2011 | 1988 Pontiac Firebird
Upon installation of a one handle Moen shower valve, water flows immediately in the off position (6 o'clock position) then reduces as valve turns counter clockwise until fully off at 12 o'clock, then comes...
you need to adjust the little gear like..plastic part under handle..plus hot water must be on so that the pressure is balance..the cartridge also needs to be adjusted so water is off on off position
Nov 25, 2010 | Moen & One Handle Tub & Shower Faucet
Our icemaker is filling the tray with water while it is still turned in a down position to dump the ice into the buck. How is this problem resolved?
ice maker calls for water at the 11 oclock pos and only for a few sec .. it cannot dump at this time becaus it's not frozen . if it is filling with water at a different pos like 6 or 3 oclock the the timing is off and you may need to repl ice mker . mm
Aug 17, 2010 | Liebherr Refrigerators
I have a crunching noise on turns or bumps evern driving slow. It is on right rear on my 2004 Accord
Jack up car by right rear wheel under control arm or axle, so its off the ground. Grab tire at 3 oclock & 9 oclock see if there is play back & forth. If play most likely wheel bearing is bad & needs to be replaced. While your there, grab tire at 6 oclock & 12 oclock, see if there is play moving in & out. If so see what suspension part is worn.
Jun 14, 2010 | 2004 Honda Accord
Need to change the ink cartridge
  • Step 1
    Purchase an ink cartridge made specifically for your printer.
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 Close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Feb 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
    I cant adjust water temp 0n a single handle kohler shower valve
    4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
    Nov 09, 2009 | Water Heaters
    Printer
    do you get an error message on the computer screen?if yes - what is that message....? I am stating the various problem causes for the issue you have stated without even knowing if you do get an error message or not.it would get resolved if you try these steps correctly as mentioned.It should be due to one of these causes. Cause ---The top cover of the printer is open. Solution 1. Close the top cover of the printer. 2. Press the RESUME button. Cause --Printer senses that there is paper being fed. Solution 1. Press the RESUME button to feed the paper. Continue with the following steps, if the paper does not feed. 2. Turn the printer off. 3. Open the top cover of the printer. 4. Make sure that paper is not jammed in the printer. 5. Lift the right black rectangular paper sensor (located in the middle of the printer just below the silver rod on which the cartridge carriage slides). 6. Make sure that nothing is stuck under the paper sensor (you can blow under the sensor to remove dust). 7. Close the top cover of the printer. 8. Turn the printer on. 9. Try printing again. cause --The printer was waiting for you to insert paper and then did not print. Solution Press the RESUME button to eject the printed page into the OUT tray. cause --Printer does not sense paper in paper tray. Solution 1. Check to see if there is paper in the paper tray. 2. If there is paper, remove the paper. 3. Make sure that the paper width and paper length adjusters are set for the correct paper size. 4. Load paper in the paper tray. 5. Press the RESUME button. cause --The RESUME light blinks when the computer is restarted or turned on. Solution ---This problem may occur when the printer is on before the computer is turned on or restarted. The printer should be turned on after the computer is turned on and turned off before the computer is turned off or shut down. Press the RESUME button to clear the printer and get it to the normal state. cause--Printer detects a faulty, missing, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. The RESUME light will flash until it is closed. 2. Pull the top of the cartridge towards you until the cartridge unsnaps from the cradle. NOTE : Make sure not to touch the copper-colored contact tape on the back of the print cartridge. 3. Click here (bpa00585) (in English) to check that you have the correct cartridges. 4. If you have the correct cartridges, then pick up the black cartridge. Notice that it has an arrow on the top. 5. Hold the cartridge so the arrow on the top is pointing towards the printer. 6. Tilt the cartridge slightly towards you. 7. Keep the cartridge tilted slightly towards you as you insert the cartridge into the right cradle. 8. Push the cartridge firmly forward into an upright position. You will hear a click when the cartridge is firmly in place. 9. Pick up the color (called tri-color) cartridge. Notice that it has an arrow on the top. 10. Hold the cartridge so the arrow on the top is pointing towards the printer. 11. Tilt the cartridge slightly towards you. 12. Keep the cartridge tilted slightly towards you then insert the cartridge into the left cradle. 13. Push the cartridge firmly forward into an upright position. 14. Close the lid of the printer. You will hear the sound of the cartridge cradle as it moves to the right side of the printer. cause --The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. (Distilled water is recommended. Tap water might contain contaminates that could damage the cartridge.) NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Turn off the printer. 5. Unplug the power cord from the printer. 6. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp, lint-free cloth. 7. Use a dry, lint-free cloth to remove the moisture from the contacts. If the carriage contacts show noticeable damage, have your printer serviced. 8. Plug in the power cord. 9. Try printing again.
    Sep 24, 2007 | HP DeskJet 648c InkJet Printer
    Danco Faucet Cartridge  Logo
    76 people viewed this question
    Top Danco Home Experts
    Andrew Bugbee
    richie46
    Joe Olszewski
    Level 1 Expert
    Are you a Danco Home Expert? Answer questions, earn points and help others
