Question about NEC Dt700 Series Phone Itl-2e-1 690000
Dt700 series phone not ringing only led
When a call comes in the phone isn't ringing, only the red led flashes. I tried turning up the volume while it rings but nothing happens
  • 201 Answers
SOURCE: Blinking light but no ring sound on incoming calls
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
Posted on Oct 18, 2007
  • 43 Answers
SOURCE: LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
Posted on Feb 12, 2008
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
  • 43 Answers
SOURCE: Ring Volume
Press FEATURE - 0
use the arrow keys to adjust
press FEATURE
SOURCE: DO not disturb feature will not turn off
do not pick up the headset
push feature 69 feature
Posted on Mar 06, 2009
Turn ringer volume up on NEC Dterm series i? I have tried adjusting while ringing but the LED volume shows up still
You need to lift the handset first then adjust the volume via the large silver round button on bottom right of phone
Feb 27, 2015 | NEC Lands Phones
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
My lg kf750 secert has no sound. I have checked volume. When the phone rings there no sound and i can't hear person on line but they can hear me.
Firstly, try to go to 'Menu > Settings > Reset settings'. This will clear only your personal preferences, thus not touching your applications or personal data. However, ff you keep having problems with your sounds, perhaps a hard reset could sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all programs you have installed, as well as your personal data. To perform a hard reset, turn your phone off completely, by pressing and hold the power button and answering to the prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue. When your device powers up, it should be completely clear now.
Hope it works for you, since this is pure theory. I have never done it myself.
Cheers! Carlos
Apr 17, 2010 | LG Secret ? KF750 Cellular Phone
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
New Uniden Phones don't ring in!
check to see if there is a ring volume button on the rear or side of the base of the phone console.
Check the handset and look for volume as a call comes in press the volume up button to see if it increases.
May 28, 2009 | Uniden Cordless Phone
Red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
May 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
My phone doesn't ring
While the call is ringing in, try pressing the up volume button. Maybe he turned the volume off.
Jan 08, 2008 | NorStar T7316E Corded Phone
NEC Dt700 Series Phone Itl-2e-1 690000 Logo
56 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
