Question about Mercedes-Benz S420 45045 Universal Cargo Mat
Why do my mercedes benz c180 delays to start once the engine is hot
C180 2000 model
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Is it dead? or does it try to start?
Posted on Mar 05, 2014
My c180 2005 model had wouble engine noise when i started the engine to have it parked in the garage. Engine light was on. I drove it within 5metres into the garage. I towed it o mercedes and they d
Check the spark plugs, the spark plug wires and the coil packs. If they are good then the misfire could be caused by the Mercedes ecu computer. If you are not sure go to http://www.mercedesecm.com for more information about ecu misfire problems.
Dec 31, 2014 | 2002 Mercedes-Benz C180
Why is my C180 2011 model does not start,yet the key functions well.
This could be the ecu control unit. Mercedes Ecm Repair
Sometimes a bad ecu will make a Mercedes misfire or not start. But the problem could also be related to a bad ignition key. You will need Star diagnostics to troubleshoot the vehicle.
Oct 16, 2014 | 2002 Mercedes-Benz C180
Mercedes benz c180 timing marks
TRY GOING TO THE SERVICE AND REPAIR DEALER AND ASK IF YOU COULD GET A COPY OF THE C180 TIMING MARKS DOESNT HURT THE EFFORT
May 10, 2014 | 2002 Mercedes-Benz C180
My year 2000 mercedes benz C180 delays to start when the engine gets hot
Hi. when an engine is not easily start when is hot,one of the most reasonable things is that the valves are not kept close enough to make the engine having the expected compression to have an easy start up. this happens either from the long miles engine oil change where the old and late changing oil builds up carbon inside the engine and also on the hydraulic lifters which are adjusting the valves opening and closing position. My mechanical advice is for first try to do an engine oil flush,by using (RESTORE ENGINE OIL FLUSH) just open the oil filler cap,pour into the engine old oil,start the engine and let it run for 40 minutes in every 10 minutes just give it an acceleration up to 2000 revolutions for a minute,let it back to idle and after 10 minutes do the same thing until comes to 40 minutes ending time. After that just switch the engine off,drain the old engine oil by opening the oil sump plug. Remove the old oil filter,clean the filter place use a new oil filter, sump plug on, put a new engine oil 5w30 fully synthetic oil, use also if you do have (RESTORE FRICTION REDUCER ) as an additive for the engine oil,start the engine and do the same thing every 3000 miles and not for long miles engine oil change. I strongly believe you will notice the difference. For any queries please do not hesitate to email me. Good luck.
Feb 13, 2014 | Mercedes-Benz S420 45045 Universal Cargo...
Mercedes c180 steering
DID YOU RETURN EACH HOSE TO ITS ORIGINAL POSITION. SOUNDS LIKE YOU HAVE THE PRESSURE AND RETURN IN THE WRONG PORTS
Sep 19, 2013 | Mercedes-Benz Cars & Trucks
Hi, I have Mercedes C180, I have changed both Sam units. Now it's battery keep draining out. Once it's starts its run fine. Can some one help me please.
Don't you have some warning lights on your dash? MB cars are fly-by-wire that tend to depend so much on battery electricity when shut off. Use a high amps battery or battery recommended matching your car model. Check on some instruments that can be a parasitic drain to your car like, car alarm, sticking relays on auxiliary fans, radios. Worse you have a short somewhere or a wiring harness issue, but it should be giving you a warning on the dash.
Sep 26, 2012 | Mercedes-Benz Cars & Trucks
Mercedes c180 2002 model
Well the first thing i would do is scan the computer for codes,but without a scan reader you cant. see if it has fuel preasure,start there.
Feb 26, 2010 | 2002 Mercedes-Benz C-Class
How to start Mercedes C180 1999? Is it button start or key start?
i have a c180 merc petrol when starting the starter dosnt engage prop for afew turns then it engages and engine starts i have change the ring gear plus change the starter and still geting the same prob
Jun 28, 2009 | 1999 Mercedes-Benz C-Class
Mercedes-Benz S420 45045 Universal Cargo Mat Logo
71 people viewed this question
Top Highland Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Highland Vehicle Part and Accessory Expert? Answer questions, earn points and help others
