Question about Frigidaire Washing Machines
I have a frigdiare combo washer/dyer i replaced a faulty door switch and the washer would not start what should i check model number is FFLE1011MWO
  • Frigidaire Master
  • 5,323 Answers
CHECK FOR BLOWN FUSE
Posted on Apr 01, 2015
  • 15 Answers
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
  • 23 Answers
SOURCE: dyer on combo won't start
This could either be a bad start switch or door switch
Posted on Nov 04, 2008
SOURCE: the door switch on my
looking for door switch for Philoc washer model # MWS939ZAS2 50 HZ
Posted on Nov 30, 2010
tunde007
  • 2382 Answers
SOURCE: FRIGDAIRE WASHER FRONT LOAD MODEL#GLTF1240ASO
Hi, are you sure your pump is operating properly any little thing caught in the impeller will stop these pumps. You also say there water still in the tub it will definitely not spin fast with water in the tub. Remove the pump and inspect the impeller sometimes there are things caught in it and other times the vanes are broken right off.
Posted on Apr 21, 2011
mc1bean
  • 3053 Answers
SOURCE: top load Ge washer model number WVSR1060A1ww will
There can be many reasons and i will do the best to cover everything that can happen with your washer to cause it from not draining or spinning. I will attempt to cover the basic things that can happen with washing machines.
First thing to check if your washer is not pumping or spinning is to see if the motor is running. If themotor is not runningb>then check the lid switch. When the lid gets slammed it hammers that switch and eventually will bend it or break it completely. Some washers will wash but not spin or pump, others will do nothing. This switch is located under the lid on the edge of the frame around the lid. Often there is a hole that a pin from the lid will go through and push on a lever that is the switch. Check that it is not simply bent, so that it does not trip the switch inside anymore. To change or check the switch the top will need to be raised or the front removed. Getting to it, is often harder then the replacement.
Thank You, Mike Here is also My personal Sight to Help with other problems you might have as well.
Posted on Oct 03, 2011
Maytag neptune model mhs2000aww stackable dyer works but washer side not getting power why
test this steps and fix it. God bless you
  • No power to the washerMake sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
  • Lid switchThe washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defectiv
  • Read more: http://www.appliancepartspros.com/repair-help/washer-repair-help.html#1#ixzz2gUeyhEyb
    Oct 01, 2013 | Maytag Neptune Washing Machines
    R1 wont start
    see this steps and fix it. God bless you
    User Control and Display Board
    If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
    Enter your model number to see parts for your washing machine.
    Help me find my model number
    Timer
    If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Line Fuse
    If the washer won't start the line fuse might have blown.
    Thermal Fuse
    If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
    Line Fuse and Holder
    If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
    Main Control Board
    If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
    Door or Lid Latch Assembly
    If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly
    If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Incoming Power Problem
    If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
    Power Cord
    If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
    Jul 21, 2013 | Motorcycles
    Stat button
    see this steps and fix it. GOD BLESS YOU
    Timer
    Line Fuse
    Thermal Fuse
    Main Control Board
    Power Cord
    Jul 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washing machine wont turn on
    see this instructions and fix it. God bless you
    Timer
    Line Fuse
    Thermal Fuse
    Main Control Board
    Power Cord
    Jul 21, 2013 | Washing Machines
    Isnt gettin power but cord work outlet works
    Timer
    Line Fuse
    Thermal Fuse
    Main Control Board
    Power Cord
    God bless you3958e768-3a49-432b-8096-35c2e90be05f.gifbf55c0bf-2b61-4cdd-8831-a6dc82140f68.jpg
    May 23, 2013 | Maytag MAV7600 Top Load Washer
    Maytag washer mav7600aww doesnt get power
    Timer
    Line Fuse
    Thermal Fuse
    Main Control Board
    Power Cord
    God bless you938a0a02-c262-417d-a982-3a081cef735f.jpg2b39c595-65d9-457a-8ed4-d3bb6d2facd8.giff6783cbc-852f-47b4-98d7-bd94a664080e.gif
    May 23, 2013 | Washing Machines
    Simpson swt802sa
    he most common parts or causes, ordered by the likelihood of fixing the symptom.
    Timer
    Line Fuse
    Thermal Fuse
    Main Control Board
    Power Cord
    God bless you11c63312-8cb1-4484-928d-4b5c239b0f35.gif243403b0-440d-4f8b-b217-fdfd20c409ef.jpegc0210118-4dbd-4ea4-980b-16577c9769fb.gif
    Dyer on combo won't start
    May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
    Power Surge and WD16BA
    Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
    No power Check the flex, plug wiring, fuse and mains supply for faults.
    Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
    Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
    Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
    Washing Machines Logo
    80 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
