Question about Epson L200 All-in-One Inkjet Printer 27 PPM Black, 15 PPM Color, 5760x1440 DPI, Color, PC
Scanner stuck when turned on
When i trun on the printer... scanner got stuck the right side... and the printer can't print file.... sorry for bad grammar :(
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Manual, manual, manual READ it that's what it's for. Call Epson for help.
Posted on Apr 29, 2014
3 Suggested Answers
gwbm
  • 353 Answers
SOURCE: my epson stylus C42UX printer cartridge is getting stuck
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right hand end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below), or some other mechanism fault.
If you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above! If you want to have a go at doing this yourself, please report back for help on this.
If neither of these apply, please report back for further help.
Posted on Feb 10, 2009
sabharish
  • 297 Answers
SOURCE: YAGNESH BHATT- EPSON LX-300+ PRINTER GETS STUCK
There are quite some possiblities causing this problem:
1) The ribbon cartridge must be stuck in the inside causing a stuck up with the Timing belt gear mechanism. Remove the cartridge and try printing on plain paper.
2) One of the gears at the right and left of the belt is dislodged or dust must have accumulated casuing a jam.
3) The belt motor which is towards the right is dislodged sacrificing the tension that the belt needs.
Thank you!
Sabharish
Posted on Nov 02, 2009
Bizhub284 prints but there is no ink on paper
all colors? check the sponge looking roller right side door in correctly, check print try to catch the printer in doing a job open the right side during a job is there toner on the transfer belt across from the sponge roller. does this happen during copy does demo page and meter count page come out ok, try different file also and program pdf or web page etc.
Apr 22, 2014 | Konica Minolta Bizhub C284 Color Copier /...
I interrupted a huge print file and a page is stuck in the printer
Open the Printer from PRINTERS AND FAXES or DEVICES AND PRINTERS and double click on the icon and right click on each print job and press delete
Dec 14, 2013 | Brother HL-2240 Monochrome Laser Printer
How to access print queue
You can find the print queue going to Start-Settings-Printer and Faxes, Open printer and faxes by clicking and You will find the printers installed. Select your printer probably the one which has tick mark on it ( default printer) double click to open and see the files in queue. You can delete the queue if printing stucked.
Other way to delete the printing queue if not getting deleted from the above method is to go to start-.>run type "services.msc"
search for print spooler service in the rights side pane, right click the service and stop it. Now again go to Start->run type
"spool" and hit enter. It will open up folder for you, double click on PRINTER folder and delete all the files in that folder. This will clear up the queue from printer. After deleting all files, go to again follow the same process to start the print spooler service. Go to start->run-> type "Services.msc" hit enter, on the right side pane search for printer spooler service, right click and start the service.
Hope this helps
May 19, 2010 | Microsoft Office Home and Student 2007...
My canon ip4300 is stating error B200 and flashing amber and green light at front. I cannot get to the printhead as it is stuck to the right hand side.
Turn off the machine, and unplug the power cord of the machine from the power supply. Then trun the Printer On again, if the problem is not resolved, please let us know.
May 05, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Can I reset the printer head on my Brother DCP-310CN printer. I'm getting an error message "unable to clean" & the print head is stuck to the right of the machine.
Same problem ,head over to right side- stuck - spent an hour and decided to dump it ,time better spent getting new, thats it, sorry
Apr 05, 2010 | Brother DCP-310CN All-In-One InkJet...
My printer/scanner says that for some reason,
The ink is very caustic, it may have seeped out of the sump and ruined the print heads. No way to repair, sorry.
Oct 17, 2009 | Office Equipment & Supplies
Carriage cradle stuck on right side!
Carriage system is broken. Uneconomical to repair. Sorry
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
HP PSC 1410 will not print, printer icon is no longer on the bottom right hand corner of screen either. When i turn off the printer and turn it back on it prints the test page only.
Dear kappa, It is the problem related "Alignment of cartridge" your printer is working properly, I am suggesting a method, with the help of this method you will never get test page until you lift out your cartridge from your printer. When next time printer print a test page, take it and put it into the scanner, remember the printing area should be the side of mirror and the printer prints on the above side of the paper should be left side of the scanner. And press scan button, you will see the green light will be blink and a voice of scanner you will hear. After 30 seconds light will stop blinking, Next time when you will turn on your printer, it will not print test page.
Sep 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
Epson L200 All-in-One Inkjet Printer 27 PPM Black, 15 PPM Color, 5760x1440 DPI, Color, PC Logo
227 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
