Question about Samsung Heating & Cooling
Air swing not working - Samsung Heating & Cooling
The air swing button is not working
moat air conditioners suffer this fault after time
research has shown the the small plastic gears in the actuator , break teeth
the only repair is a new louvre actuator assembly unit if they are available from the service agent
May 27, 2015 | Heating & Cooling
What does the "swing" button do on the soleus ac/heat remote control?
The swing button on the unit itself turns on the horizontal oscillation of the louvers. The remote's swing button adjusts the speed of the oscillation. In the fan mode, it lets the Soleus Air Conditioner circulate more air.
Home Depot has the manual for Soleus PH3-12R-03 here: http://www.homedepot.com/catalog/pdfimages/d4/d4382c05-2692-4075-a254-fdcdef6dc1fb.pdf . The buttons are the same across the units.
I hope this helps.
Jul 17, 2014 | Soleus Heating & Cooling
Swing not working
clean pivoting and mechanical parts and lube
Mar 16, 2014 | Heating & Cooling
Swing flap not working
Remove cover check cogs attached to motor and check if motor is moving when set to swing
Nov 23, 2011 | Heating & Cooling
Airswing function not working on panasonic aircon split system
Remove side screws and pull out the PCB compartment, and check wiring to swing motor. Most of the time, the clip would have been removed on transportation or during service time. If connection is good, replace swing motor. Thanks.
Feb 05, 2011 | Panasonic CW-XC83HU Air Conditioner
Air swing has stopped working
Check power to air swing. if it's in window a/c. If power, motor is struck or open.Replace motor.
If it's with DC connection, you have to replace motor if not working. Thanks.
Feb 05, 2011 | Panasonic Heating & Cooling
My LG art cool a/c blades in the vent arent swinging (from left to right)as i keep pressing the swing key on the remote.. please help
In some models, there are swing and sweep motors. Swing will work the vent up and down. Sweep or air flow motor will work for louvers left to right. If sweep motor not works replace the motor. If no sweep motor option, you have to direct by manual only. Be care ful, when you are doing manually, switch of the unit. Thanks.
Feb 01, 2011 | LG LSC121PMA Split System Air Conditioner
Swing is not working at all
are the linkages to the swing motor broken?
is the swing motor working?, if not then it is either the swing motor switch or the motor its self
May 02, 2009 | Whirlpool ACQ108XL Air Conditioner
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
We can off the swing mode in spilt AC?
just click on the swing button if it is on it will turn off if it is off it will turn on but make sure u point the remote towards the ac
May 07, 2007 | Electrolux E23CS75SS Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
