Question about Nikon D5000 Digital Camera
My camera wont take pix says slide lock to write position, when I do that it display "CHA" don't know what that means and still can't take pix
Camera said memory card locked slide to unlock, did that, still cant take pix on any memory card and display says "CHA" don't know what that means or how to fix the problem, please help
    Top Expert:
  • Nikon Master
  • 6,702 Answers
CHA also means the card cannot be used for other reasons. F.i. the card can be damaged. Try to format the card. That is, when you could use the card before. If you bought a new card, Make sure it is not a SDXC card, because your camera only allows MMC, SD and SDHC cards. If nothing helps, also look in the memory card holder, if nothing strange is in there, or the sensor that looks for the lock, is functioning correct. If you don't know how, please visit or contact a Nikon-Authorised service centre.
Posted on Feb 13, 2014
5 Suggested Answers
SOURCE: cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Posted on May 06, 2009
  • 9 Answers
SOURCE: Camera is saying "Memory card is locked. Slide lock to "write" position."
If you remove the card from the camera, there is a little switch on the SD Card. There is typically a label that shows which direction is locked. If not, switch it to the opposite side. This should solve the problem. Otherwise, there could be a problem with your card. I hope this solves the problem.
Posted on May 17, 2009
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
  • 406 Answers
SOURCE: the problem is Memory card
Hi there fellow Nikon user, I understand that you're having issues with your memory card. You mentioned that you already put on the unlock/write position but you;re getting the same error message. There's a big possibility that the card's locking mechanism is damaged. I suggest that you try a different memory card to isolate the problem. If inserting the other card doesn't fix the problem, Then most likely it's the card slot itself that is already busted. Have it checked right away by an authorized Nikon technician.
However if the other card was accepted and you're able to write info with it, then we can conclude that the memory that you're having problems with should be replaced.
Hope this help. Cheers!
Posted on Apr 11, 2011
D55ir xt says trail card lock when you turn it on an wont take pix
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 01, 2012 | Moultrie D55IR Digital Camera
Nov 01, 2012 | Moultrie Cameras
CHA is blinking on the control panel, and on the viewfinder it says Card is locked. Can't get rid of these things, and obviously can't take pix. We just charged the battery before Easter and haven't been...
First, remove the memory card and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. Then put the card back into the camera and format it by pressing and holding the two format buttons (trash can and exposure compensation buttons) until the LCD blinks. Release and then press the two buttons again to format the card.
If this doesn't do it, please reply to this post and we'll go on from there.
Apr 29, 2011 | Nikon D80 Digital Camera with 18-135mm...
CHA flashing on readout screen. Battery is fully charged. What does CHA mean?
If there are brackets around the CHR, it means the card is locked. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If there are no brackets around the CHR, it means the camera cannot read your memory card. Try a different card.
Dec 12, 2010 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D50 Digital Camera. I cannot take a picture, the letters CHA are flashing on the screen.
If that doesn't do it, try a different card.
Aug 27, 2010 | Nikon D50 Digital SLR Digital Camera with...
The camera is flashing CHA. It won't let me take a picture
If that's not it, then try formatting the card.
If that doesn't do it, try another card.
Aug 27, 2010 | Nikon Cameras
Put in memory card flashes CHA and says card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again. Put the card back in and format it.
Jul 28, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Reads Card locked when trying to delete pix from mmemory card
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 25, 2009 | HP Photosmart M425 Digital Camera
SD card locked for Samsung SL202
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Sep 03, 2009 | Canon PowerShot A560 Digital Camera
Nikon D5000 Digital Camera Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
