Kohler 30RESA 30kW Standby Generator Beige, Standby Logo
A
Anonymous Posted on Feb 13, 2014
I have a generator Kohler Model 30 RES IT CRANKS AND RUN FOR FEW SECONDS AND SHUTS DOWN
5 Related Answers
Anonymous
  • 169 Answers
  • Posted on Dec 03, 2008
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Anonymous
  • Posted on Oct 09, 2009
SOURCE: kohler lp shuts down
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Anonymous
  • Posted on Sep 20, 2010
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
did you put the propane orifis in and unplug the spark wire
Steve
  • 12 Answers
  • Posted on Nov 29, 2012
SOURCE: I have a Kohler 12RES, 12.5kw genset. Less than a
Replace mag pick up. Cranking voltage on the MPU should be at least 2 volts AC. Normally MPU goes out.
Steve
  • 12 Answers
  • Posted on Nov 30, 2012
SOURCE: I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
2answers
Why my generator shuts down and posts a message cc-1 crank cycle
Maybe the start motor is damaged. You can check it first.
Power generation: www.dieselgeneratortech.com
1helpful
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
1helpful
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
Generator starts then shuts off in 8 to 10 seconds it shuts down
Check oil, and sensor, rotor rings, and brushes, then stator rotor for shorts
1helpful
3answers
Kohler lp shuts down
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
