Hls5679wx xaa No red color ,then solorizing,tryed to reset factory settings ,mute 182 power,now it powers up but no pitcher or sound on any inputs
Can I use dongle on my median tablet
Posted on Feb 13, 2014
SOURCE: 51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Posted on Nov 24, 2007
Ecollier2012
  • 3459 Answers
SOURCE: Samsung HC-P4752W power and/or convergence problems
Sounds like you soldered two of the convergence pins together by accident. If its shorted the TV will shut down.
Posted on Mar 29, 2009
SOURCE: samsung dlp hln617w aging pattern problem
I am actually having the same problem. I just reciently installed a new bulb and messing around in the service menus, and ended up with the same problem. I found that if if in the same menu the aging pattern was in, I think it was the last menu, and click on the EW RESET, let the TV reset and that should fix your problem.
Posted on Dec 04, 2009
SOURCE: I have a samsung HL-S5087W it will turn off by
your problem is your No 2 Fan needs to be replace I have had the same thing happen to me.
Posted on Apr 22, 2010
tvtek
  • 1284 Answers
SOURCE: Samsung HLS5679WX/XAA DLP TV set. Problem when I
Check for a defective lamp. Open the access door where the lamp is, remove it and see if visually it looks defective.
Posted on Sep 08, 2010
Lcd tv repair problems
reset to factory settings presing (MUTE+182+POWER ) on the remote control and choose factoy reset.
this must be done with the tv off.
Aug 13, 2014 | Samsung Televison & Video
Samsung 32" (ln32a300j1d) color is a bit off. Everything looks a bit faded, is the best way to describe it.
If you have a lot of hours on it, you may have bad CFLs which are part of the LCD panels asssembly. A picture is worth a thousand words. post a pix!
Dec 03, 2013 | Samsung Televison & Video
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Samsung LN22C350D1D FACTORY SETTINGS??
1. Do what you did, enter to service mode, and reset to factory default.
2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How do i reset lamp timer Model #HL-S4676-SX/XAA Samsug tv
Hi:
Using the original remote, while the unit is off hit the Mute key then push 182 then the power button, this will take you into the service mode, use arrow keys to scroll down to different options and push enter, do this until you see lamp reset push enter to reset, then turn power off to exit service mode.. Do not mess with any other settings in this mode.
Jan 21, 2010 | Televison & Video
Cannot get sound out of my samsung T200 HD 20inch on cable tv any ideas how to turn it on ?
ANY PROBLEMS LIKE SOUND PROBLEM turn off moniter ( power supply on) then press MUTE+182+POWERON TO GO SERVICE MENU THEN OPTION BYTE --> FACTORY RESET . TO SOLVE PROBLEM .
Dec 31, 2009 | Samsung T200HD LCD Monitor
Mar 29, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HLS5679WX/XAA turning on and off
I had this on mine too. It is a problem with the power supply. Samsung knows about it.
Nov 06, 2008 | Televison & Video
Color
there may be a jumper to remove on the DMD board, some of these models require it, it could be a factory setting, there may be 2 choices of color wheels in the factory mode, the way you get into the factory mode is with the Samsung remote that came with the tv, hit the MUTE button then 182 and then the power button, may take a coupls of tries before it works, good luck
Jul 18, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Dark greys appear a dull green.
could be a jumper that needs to be removed on the DMD board, or a setting in the factory mode, mute-182-power will get you in there
Jul 11, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
