Question about GE Spacemaker JVM1640SJ Microwave Oven
JVM1460WA light and fan stay on after cooking
Only way to turn off fan is to open door. everything else works fine. Light also stays on when door is closed.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
One of the door s
Posted on Sep 23, 2014
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: GE Profile Convection/Mircowave Oven Hood
Hi
Thanks for using FixYa. From what you have described the issue seems to be with the door switch that has gone bad and should be replaced as everything else is working fine so don’t think its fuse or anything else that has gone bad. Please do accept the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Sep 02, 2010
  • 6771 Answers
SOURCE: GE Profile (modelno JE1590SH01) won't turn off (but the light goes off) after cooking unless you open the door
There probably is a bad micro switch that needs to be changed.
Posted on Apr 05, 2012
I have a Sharp Microwave R-530E-S, when I put power on it it the interior light comes on and a fan (I think it's the cooling fan?), when I open the door the fan switches off and obviously the
First of all, you should not open the door when the unit is in operation. This may cause this problem. The light should come on when the door is open, even if interrupting a cook cycle. I'm not sure then that I am understanding the description of the problem.
Jan 29, 2015 | Sharp Microwave Ovens
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 08, 2014 | Microwave Ovens
Microwaves fan and light on permanently
One of the relays is stuck. Hit it firmly and see if the fan turns off
Nov 28, 2013 | Sharp 2.0 cu.ft. 1200 Watt Microwave -...
Sharp combo microwave: Turntable wont stop unless I leave the door ajar. Light stays on too while turntable is going. Everything else works fine - it just doesn't know when to shut up! :)
It's a door switch that's bad. Probably the secondary interlock switch. You need an ohm meter to verify switch not 'making' electrically. Usually the only thing that causes this switch to fail is from opening the door when the microwave is cooking, secondly, by cooking at very extended lengths of time.
Aug 28, 2013 | Sharp Microwave Ovens
Maytag microwave "turntable", light and cooling fan stay on after cooking complete.
you can leave the door ajar for a change - it also eliminates the odor inside the microwave
Oct 26, 2012 | Maytag JMC9158AA Microwave Oven
Amana Microwave stays on when I shut the door.
It'll be a bad door switch or a loose door switch mount.
See :
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
William E. Miller
prototech@usa.net
Sep 09, 2009 | Amana Radarange Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
147 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
