Question about Xerox 3030/3040/3050/3060/8830/8825 Developer
Xerox 3030 the copy has a 2" wide black streak.How can I fix it?
  • 1003 Answers
SOURCE: Xerox Copier XC356 gives only all black copies.
WITH THIS PRINTER ITS CHEAPER TO REPLACE THAN REPAIR SOUNDS LIKE THE LED OR ILLUMINATIN LAMP IS BLOWN
Posted on Jan 23, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8400 Streaking
You can go into the trouble shooting menu and do the "eliminate Light stripes" procedure a few times.
Then you can do Jet substitution from the same menu.
If that does not work then most likely you need a new print head.
If you have used non xerox ink sticks that is your most likely cause of the problem. cheaper is not always better
Posted on May 30, 2008
copiersplusw
  • 136 Answers
SOURCE: Dark streaks on copies from Xerox XC356 copier.
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Posted on Mar 05, 2009
goodgold
  • 389 Answers
SOURCE: I require a service manual for a xerox 3030 wide
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Posted on Oct 17, 2009
  • 100 Answers
SOURCE: What could cause wide black streaks when I try to
you may see the drum surface if there are black line left. if there is then you're having a problem with your drum unit; most probably the cleaning blade of the drum. :)
what is the model number of your machine anyway?
Posted on Mar 23, 2010
How do i get rid of streaks on copy. There are 3 black streaks on each copy. I have a xerox 420dc
Print heads need deep cleaning. If not ink jet, then the drum is damaged (scratched) and needs to be replaced to eliminate the bogus lines.
Jan 17, 2017 | Xerox Document Centre 420 DC Laser Printer
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
I have a hp 3030 printer and when I replaced the ink cartridge it started making black streaks accross the paper, every 2-3 inches and there is a double image of the picture being copied.
Hi:
After replacing the cartridge it is mandatory that you do a cleaning cycle and head alignment to insure the cartridge is aligned properly for printing.
Jul 14, 2011 | HP Office Equipment & Supplies
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
What could cause wide black streaks when I try to make a copy? I cleaned the tranfer corotron, but still have the streaks. No warning lights come on for toner or drum cartridge replacement.
Mar 23, 2010 | Xerox 8830 Copier
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Sep 02, 2009 | Xerox Office Equipment & Supplies
Xerox xc 830
pls check ur machine ros assembly unit. i think the ros assay geting dust or its geting failed.
Jul 23, 2008 | Xerox Office Equipment & Supplies
May 28, 2008 | Xerox Phaser 8400 Laser Printer
Xerox 3030/3040/3050/3060/8830/8825 Developer Logo
42 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
