Question about Tricity Bendix TM310W Electric Dryer
Door Reversal Electric connection
How to move the electric latch connection from one side of the dryer to the other
Opening door does not stop tumble dryer--kenmore 80
The door latch functions as an electrical interlock. If the dryer continues rotating with the door open, the latch may have failed or something may have gotten jammed in it
Oct 08, 2013 | Kenmore 62802 Electric Dryer
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
I have ordered a door latch assembly for my cabrio dryer wed6400S. How do I install that latch? Do I take the door apart by unscrewing or just pull that latch out. It is broken and just wiggles. Thanks
open dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
latch assembly:
http://cgi.ebay.com/Dryer-Door-Latch-Catch-279570-fits-Whirlpool-/330503664154?pt=LH_DefaultDomain_0&hash=item4cf38db21a
Dec 02, 2010 | Whirlpool WED6400S Electric Dryer
Maytag Neptune MDE6800AYW shows error DO (Door Open?) bu the door is closed and the machine would not turn on
door switch, it is located inside the dryers front panel, there are a total of eight screws to take the front panel off, hinges have four and lift up an out, the other four are on the opposite side there are white plastic fillers(this is for door reversal), the panel lifts up and out. Here is a website to check the switch, may have a broken keepers,loose/broken wire or just a bad switch. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 07, 2010 | Maytag Neptune MDE6800 Electric Dryer
What does the reversal kit consist of
As far as I know there isn't any "kit" needed to switch a door. It's just a matter of taking out a bunch of screws, reversing some door parts, and putting it all back together. Here's a link that shows how to do it for one model which is typical:
http://www.maytag.co.uk/Assets/U&C_MDE3706AGW.pdf
About all you need is a phillips-head driver and maybe a small putty knife to pry out the filler plugs from the holes you'll be using.
Feb 21, 2009 | Maytag PYE2300AY Electric Dryer
Broken latch on dryer door
buy new latch and striker. cheap.
Jan 17, 2009 | Whirlpool LER4634J Electric Dryer
Door reversal?
Sorry, dryer doors are reversible, but not washer. Please don't rate this as anything but a FixYa lowers my overall score.
Dec 01, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer problem
with power disconnected
follow the wires from the start button, to a relay,
check the wires (both ends) of all leads to the relay and reconnect any that have fallen off. (crimp tighter if they have fallen)
Check door switch function and connection.
check timer connections
the relay start-button timer and door switch comprise a latching circuit, when the start button is pressed the relay is supposed to latch closed and supply current to heater and motor. if the latching circuit disconnects the relay does not latch closed, and only runs as long as the start button is pressed.
if nothing has disconnected one side of the relay has usually failed, and the connection is not being made to latch the circuit
replace relay
cd48320.jpg relay is shown at right, 2 switches connected by a dashed line.
Oct 12, 2008 | Kenmore 62602 Electric Dryer
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Oct 03, 2007 | Whirlpool GEW9250P Electric Dryer
Tricity Bendix TM310W Electric Dryer Logo
Top Tricity Bendix Dryers Experts
Tim Whalen
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
