Question about Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range
Belling DB3 Control Panel
I need to renew the electric oven controls on my Belling DB3. I have removed the 3 screws at the bottom of the control panel but I cannot remove the panel from the cooker. Any ideas as to how I can do this?
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Posted on Apr 09, 2008
  • Rita Hilton
    Rita Hilton Feb 04, 2014
    We see clips but cannot see how to get them off.
Oven keeps blowing thermal fuse
  • Disconnect the oven's power supply by turning off the breaker in your home's service panel.
  • 2 Open the lower oven door. Remove the screw at the bottom of the trip panel on each side of the oven.
  • 3 Pull the trim away from the oven approximately 2 inches, then slide the trim panel down to remove it from the oven.
  • 4 Remove the screws from the bottom sides of the control panel.
  • 5 Pull the control panel out from the bottom, then lift the panel to remove it from the front of the oven.
  • 6 Detach the wire connectors from the control panel by depressing the tab on each connector and removing it from the control panel.
  • 7 Depress the tabs on the thermal fuse wire connectors, then remove the thermal fuse.
  • 8 Attach the wire connectors to the new thermal fuse to install it in the control panel.
  • 9 Reassemble the oven by reversing the steps used to take it apart.
  • 10 Restore power to the oven.
Jan 21, 2014 | managemylife.com
Oven not heating but fan-oven IS heating
here is the link
http://www.ultimatehandyman.org/cate...pliance-repair
rate me as fixya
Jun 08, 2008 | Belling DB3 Dual Fuel (Electric and Gas)...
How to remove the touchpad on ge profile stove, I have f7 code
On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
Getting error code F7
Microwave will not operate (cook). F7 error code appears on the display. Electrical circuit interruption between L1 and Neutral in the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves the problem
A. Check the Cooling Fan for proper operation or blockage
B. Check the resistance of the magnetron thermostat. It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter is properly connected to plug P2 on the display PCB & Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W inverter.
8. If problem persists, replace control assembly.
Additionally, check this article: oven-error-code-f7-and-how-to-fix-it
Hope this helps.
May 26, 2011 | GE Ovens
The screen says F7 and an alarm keeps beeping
One of the most common problems with GE electric built in ovens is the error code "F7′ shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the "search" button and in the new window type the word "control panel" in the "search by keyword" box and click the "search" button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Oct 25, 2010 | Thermador SC302T Electric Double Oven
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    F7 trouble code
    One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
    To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
    Nov 10, 2008 | Thermador SC272T Electric Double Oven
    How to remove the control panel
    Here is how to remove the control panel. Make sure that the power is disconnected first.
    Open the lower oven door. You will see a screw on each of the side trims. There should be one on each side. Unscrew these screws. Then genlty pull out the bottom of the trim about 2 inches and then slide the top down.
    You should now see the screws that hold the control panel at the top of the oven. Remove the screws on both sides and then pull out the bottom of the control panel. You will have to lift the panel to unhook oven support at the top.
    Dec 16, 2007 | Whirlpool RBD305PD Electric Double Oven
    Belling DB3 Main oven door falling off its hinges
    The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
    http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
    Nov 23, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
    Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range Logo
    1,240 people viewed this question
    Top Belling Kitchen Ranges Experts
    Paul Carew
    John Tripp
    John Tripp
    Hjalmer Lamminen
    Hjalmer Lamminen
    Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
