Question about Raypak Pool & Spa
Boiler starts banging and jumping after 20 seconds of burner igniting and then hot water comes from the pop-off valve, what is the problem?
    Top Expert:
  • Raypak Master
  • 5,045 Answers
Water flow not enough water boiling inside check manual bypass spring could be bad if ok if plumbing bypass only open half way
Posted on Apr 27, 2016
5 Suggested Answers
  • 246 Answers
SOURCE: My TELEDYNE LAARS Boiler hammers when the main
the hammer is due to boiling inside some one has been messing with the safety controls or water to slow or no flow at all
Posted on Oct 15, 2009
heatman101
  • 43501 Answers
SOURCE: My Hayward pool heater Model
A few things to check...
Is the pump working correctly, no air locks and moving the correct amount of water...is not correct that first, it could be causing the heater problem...
Is the heater over firing and/or not shutting down on proper temperature..???
The banging may be the heater producing steam instead of just heating the water...
At any rate is you are not comfortable with troubleshooting this you should get it look after right of way!!
This may be a dangerous situation...
heatman101
Posted on May 31, 2011
adamh294
  • 310 Answers
SOURCE: When the burners ignite, within
This sounds like a low water flow situation. The heater is telling you that the high limit sensor is curring heater operation. The noises are the heat exchangers boiling the water either due to a blockage in the exchanger , a bad mixing vlve, or most likely poor water flow. This is tough to troubleshoot through a posting like this, but 1st thing is 1st. Check your water flow and make sure it is minimum 50 Gallons per minute.
Posted on Jul 18, 2011
  • 5 Answers
SOURCE: My heater is making a loud banging noise after the
https://sites.google.com/site/haywardpoolheater/
Three years and counting with no problems.
Posted on Jul 27, 2012
Right oven 2 burner natural gas.burners stay on for 20 seconds.
Looks like something is blocking the burners from the insides.. My mom has fixed a similar problem of my neighbor yesterday...the solution is to disassemble the burners and clean it thoroughly and put them back on..
Good Luck!
Eagle.
Apr 12, 2008 | Kitchen Ranges
Ignition at Orifice
The gas control valve is passing . It will need a replacement.
Mar 10, 2014 | Water Heaters
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
Ideal response 120 seems to fire up but burner light does not come on and boiler runs for a while and stops,no hot water or heating ???
If this an older style boiler remove thermostatwires
at boiler terminal board and put jumper between R and W, if boiler starts you have bad thermostat.
If it does not come on then it appers that you have
a problem with the spark ignition or glow coil is
bad
Jan 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Boiler wont work
you have a gas supply issue the baning is water hammer from the water heating
Jun 10, 2009 | Air Tools & Compressors
Ideal c24
Hi Jurgie,
I'm Harvey, the Master Plumber,
Happy to render my assistance.
This is your problem!
When you are switching on the boiler it ignites for 8 to 10 seconds, then it cuts off and the lock out lamp comes on. Pressing the reset button or turning on the hot water tap has the same effect.
I need to get the make and model of your specific boiler to give you an accurate answer!
Waiting for your response.
Harvey, your Master Plumber.
Sep 07, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Pool & Spa Logo
47 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
