Question about Garden
Landini 145 ledgend pto shaft not working
Pto shaft from gearboc not working
It's a 95 landini tractor and the tiller stops when it hits the ground
pto not properly engaged
spline stripped
sacrificial pin sheared
Jun 01, 2016 | Cars & Trucks
Will a pto pump off a 89 ford zf5 trans work on a 94 dodge nv4500.
a pto pump is an after market unit and is designed to fit any gear box
the problem s you will be experiencing is the adapter plate used to get the correct gear mesh for the pto gear and the counter shaft gear and if the pitch of the pump is the same as the counter shaft gear( may have to change the pto gear )
before you do the conversion , talk with a shop that fits pto units to discuss any likely problems and they will have access to anything needed to be successful in the fittment
Oct 28, 2015 | Ford Cars & Trucks
PTO turns with mwoer shaft disengaged, blades turn when shaft is rotated by hand. Put shaft into PTO housing and the mower wont turn.
bad pto, 400 dollar to fix but a cheap option is to replace the pto switch in the dash first, is the pto switch clicking with the key in the ON position? if it is then it is the pto clutch bad
Jul 29, 2015 | Garden
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
Landini tractor manuals
Contact dealership/service center or find a service manual online
Apr 01, 2014 | Garden
My Husqvarna YTH 145 just clicks when trying to start it
that just leaves the battery, the terminals, or the wiring.
May 23, 2010 | Husqvarna Garden
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
