Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Spin cycle very loud on ariston margarita AV839 took back off and not seemed to be supported by antthing
Ariston margarita AV839 drum is loose and very noisy when on spin cycle took back off and does not seem to have any resistance when spun by hand
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
My ariston margarita dosent want to take a wash load
Most likely the EPROM is gone, or more commonly known as the PCB (Programm Control board) and it needs replacement. Costs about £80 for the board plus installation.
Dec 14, 2009 | Ariston Technologies Ariston AWD12 Front...
My Ariston A1636S Is making a very loud crackling or rattling noise when it spins. Almost like something is loose inside it. I've checked and nothing has fallen into the drum. Can someone help?
Remove the dive belt, and spin the drum by hand, if it feels rough or is noisy, then the main drum bearings have failed, if no noise, then look elsewere.
Thanks.
Sep 08, 2009 | Washing Machines
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Loud spin cycle with SAMSUNG WD J1255 loose bolt???
How old is this machine? Almost all the time this noise its the main bearing. You have a inner and outer drum, the outer drum is suspended on shocks and the inner drum which is only supported by the spindle going thru the bearing on the rear of the outer drum. I have seen many of these wear out. Also I have seen the main bolt on the drum pulley shear off.
Oct 22, 2008 | Washing Machines
Loud thumping while spinning
my friend had this happen,apparrently a bearing was leaking then finally broke!
Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
15 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
