Lg wd-80154tp showing 1e
I have lg washing machine it always showing problem 1e how can i solved this
SOURCE: machine won't wash
sent machine to scrap metal
Posted on Jan 08, 2009
Dinu_kool
  • 44 Answers
SOURCE: Owners manual for LG, WD 14336ADK
www.asm-service-manual.com/List/LG%20List%20ASM.htm
use the above link to download the owners manual
Posted on Mar 20, 2009
buffalonyman
  • 1865 Answers
SOURCE: lg washing machine error message
Possible that water solenoid valve died. Unplug the unit to clear error code, and try to fill using only hot water. Try the same procesude using only cold water.
Posted on May 02, 2009
  • 136 Answers
SOURCE: LG washing machine intellowasher 7 kg wd-8050f
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Posted on Jan 19, 2010
  • 1702 Answers
SOURCE: i have a LG WD-80154TP
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799 This should give you an answer to your problem. Good luck.
Posted on Jun 13, 2011
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
LG fuzzy logic 7.5kg WF-T753A, 1E code coming up.
water is not enough check for obstruction and water pressure
Sep 28, 2013 | LG WD-14124RD Front Load Washer / Dryer
I have problem in my lg wd-80154tp i press play butten it off
This can be due to errors on the board or it can be related to fault in the inlet valve or control panel.
Check and see if there is moisture within the board or the panel that can cause errors , if so use a dryer to warm off.
If not the board is a suspect.
Feb 07, 2013 | Washing Machines
LG WD-80154TP washing machine is showing OE, which means the plug or filter is clogged. I cleaned both and am still getting the same message. What do I do now?
have you done a reset turn off machine by the mains leave off for 10 min's make sure door is open at all times make sure machine on/off button is off and the programmer is set to the off if you havent got a off on the programmar put it on a spin program ok then switch the mains back on turn on the machine on off button then press start then shut the door that is a reset if you still have problems get back to me ok
Nov 07, 2012 | Washing Machines
This washing machine is 50/60hz but not automatic i need to change from 60 to 50 hz
Almost all electrical equipment does not require the change--50/60 will work here or even in Asia.
Oct 21, 2012 | Televison & Video
My washing machine had an error code of 1E, and now will not wash on any setting except the "quick wash" - and even then, occasionally the detergent will not go through. It is an LG front...
It is not 1E, but I.E which is "INLET ERROR", the inlet valve is not letting the water through, it does sound intermittent though, please check the following, if it does not solve your problem, the Inlet valve should be replaced (Which can be bought at any reputable Appliance Spares Shop)
- Is the tap open fully?
- Check the Inlet Hose, is it kinked in any way?
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM-2277HW Front Load Washer
I have an LG F1256QD machine that keeps stopping half way through the cycle with the message 1E displaying. I've lost the manual! Any idea how to solve the problem please?
1E = WATER INLET ERROR
• Correct water level (2 level) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Check to see that your water valves are open all the way. Check the strainer in the water hose for any buildup or blockage.
Here is the "Service Manual" for your machine.
Happy Holidays! Rick
Dec 11, 2010 | LG Washing Machines
1E error code
The IE fault code indicates that your washer is not filling properly with water.
Jul 02, 2009 | LG WD-1280FHD Front Load Washer
Lg washer wm2277
The "1e" is actually a LE or Load Error. Search for it on this site and you will find many responses covering it. Some can be somewhat serious, but the most common cause is drag on the drum due to too much and / incorrect soap. Always use HE (high efficiency detergent) and no more than one tablespoon per load.
Sep 13, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
