Question about Stihl Ts410 Ts420 Cut Off Saw Piston Kit 50mm
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
  • 39 Answers
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Posted on May 06, 2014
2 Suggested Answers
plink_plonk
  • 1807 Answers
SOURCE: ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Posted on Mar 31, 2013
Could someone tell me the difference between a Stihl TS410 and a TS420?
maybe here. http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-TS-410-420-Owners-Instruction-Manual.pdf
Mar 17, 2016 | Stihl Saws
My stihl saw ts410 runs ok but as soon as you come to rev it ,it cuts out can you help
try setting your carb, you will see three holes at the side of the machine nr to the fuel cap. the one at the bottom screw it in as far as it will go then unscrew it 4 turns, the one above it do the same again but unscrew it one and a half turns, if this dont work its possible draging air in from somwere ie, crank seals, inpluse pipe, gaskets. it will need to be presure tested.
Feb 15, 2015 | Stihl Ts 410 420 Cut Off Saw...
Ts410 wont prime
air leak in fuel system \ one of the pipes blocked (the return pipe that goes back to the tank) or pipes on wrong
May 08, 2014 | Stihl Ts 410 420 Cut Off Saw...
Stihl Ts410 hard to start and erratic running
http://www.mediafire.com/download/dk8dipzr69pksrk
I've added the breakdown manual for you, have you replaced the fuel and air filters. could be a simple issue of not being able to draw up the fuel from the tank. Stone saws deal with a lot of dust and this seriously effects their running and also their cooling capabilities.
Jan 31, 2014 | Stihl Saws
Stihl ts pull string replace
I've added the TS410 brake down as they're all basically the same and you haven't stated the model to which you're referring.
Jan 30, 2014 | Stihl Saws
Starting ts410
This might be an ignition problem... Try setting in new fuel if that doesn't work take it to the shop.
Nov 21, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Ts410 stihl saw stopped working
(cold starting)
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
When fitting coil pack on my stihl ts410 what size gap do you leave?
The thickness of a stangard business card. .010-.015
get a free manual from a Stihl dealer like www.arcolawn.com
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl Ts410 Ts420 Cut Off Saw Piston Kit 50mm Logo
149 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
