Question about Watches
How do you replace the battery in a Daniel Steiger 9051M watch?
How to open the Daniel Steiger watch to get to the battery?
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
How to open a watch
mcdevito75 here, Hello Daniel, there are several ways to open a watch depending on the kind and make of watch you have. If you can, send a photo of the back of your watch to me at my email, mcdevito@netzero.com
Jun 17, 2011 | Watches
I own a watch from Daniel Jean Richard, given to me about 5 years ago. Mother of pearl face and surrounded by 49 diamonds. I want to sell it and have contacted DJR in Switzerland and France to know more...
The best place to sell could be eBay. You can put up your own price or let the auction run. Do not be afraid to give the numbers, because without that particular watch they have no use at all. If you want to get proper estimate - visit your nearest watch repair shop and ask for detailed information. They must be able to assist you with that.
Jun 01, 2011 | Daniel JeanRichard Daniel Jean Richard TV...
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    Dead battery, how do I open?
    I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
    Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
    the details of the battery read on top the one currently inside it.
    Jan 30, 2010 | Watches
    Battery replacement - Freestyle shark watch
    Jan 30, 2010 | Freestyle Shark X 75036 Wrist Watch
    Concord Impresario battery replacement
    The watch has a tiny screw holding the back of the watch. You must use a very small jeweler's screwdriver to open it carefully and replace the battery.
    Aug 04, 2008 | Watches
    How to take off back to change battery on pulsar v783-x009 watch
    Don't even try. I take mine to the watch kiosk at sears. They open and replace the battery for a very reasonable price.
    Apr 18, 2008 | Watches
    Casio g-shock watch
    Unfortunately I am not familiar with this watch, you should try this page to find a manual for it: http://world.casio.com/wat/download/en/manual/ If not contact Casio costumer support Good luck Daniel
    Sep 05, 2007 | Casio G-Shock G510D-1AV Wrist Watch
    Watches Logo
    157 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
